brake light problems with cops,,
i got pulled last night for having a brake light out ,,it wasnt the bulb though,both park lights work till you hit the brakes then it kills the passengers side park light,,any one have a clue i need to fix it bad before i get another ticket,,,any help will be appreciated,,,thanks guys
thanks guys im going to check this out tonight ,i have to pull a 25 foot trailer with two big hard maples to a lumber yard in pikeville in the morning and kentucky state police are rough,,,,
You will discover that it's a bad ground.
To prove it, remove the signal bulb, and test to see which wire is the stop lamp and the parking lights. Cut either wire (where you can fix it, obviously) somewhere behind the socket. Now strip a small section of the covering off of the wire. You will find the bare wire strand has been "tinned", meaning it's not a nice copper color, but is turning black. Classic signs of a bad ground.
Replace both sockets and make sure they run to a new clean ground. I also had a lot of problems, with my other truck, with the quick connectors in the rear of the trucks harness, behind and above both rear wheels. The connections had failed, and that's why my brake lights, parking lights were intermittently not working.
Bypassed those quick connects, replaced the sockets in the tail lights, made sure I had good solid grounds and never an issue afterwords.
Joey-D
Dec 12, 2011 12:52 PM
radshooter
Dec 15, 2004 09:12 AM
