Brake Controllers
I like my older RedLine digital triple-axle controller the best of any I have ever used.
The brake controller don't matter a whit if the brake components on the trailer are trash.
I haven't found a set of 7,000 pound brake shoes that aren't made of the most rinky-dink high-wear material ever made.
It'd be nice if they made a good semi-metallic pad for these things.
This last set lasted maybe 25,000 reliable miles.
Also, I think 25+ feet of the same guage of wiring on the truck and the trailer might present a problem.
These trailer manufacturers expect there to be no voltage drop in the wiring over that much combined distance?
One thing I have done in the past is re-wire the brake wiring on the trailer with 10 guage wiring to combat voltage drop.
I also keep the brakes adjusted up on the trailer.
Just those last 2 things will effectively change the way even a "junk" brake controller works.
It really IS all about maintenance as much as "proper equipment".
Mark.
Mark.
I think it's a prodigy that the one Duramax has in it at work. I hate the thing, get it turned up so you can actually stop with the trailer empty using the trailer brakes, go put a load on it, and it turns itself back down to zilch again.
