brake booster
Old Mar 29, 2019 | 10:26 AM
fremec's Avatar
brake booster
Is it common on the 1`st gen to replace the brake booster on high mileage diesels? Not braking like before,changed the master cylinder and peddle has longer travel than before,system was bled properly
Old Mar 29, 2019 | 11:07 AM
Fordzilla's Avatar
One example of a weak booster would be a hard pedal with shortened pedal travel, not longer......Ben
Old Mar 29, 2019 | 05:40 PM
Air in the system usually is the culprit for a longer peddle travel. Did you bleed the RWAL valve first before moving to the rear wheel cylinders?
The Vacuum brake system is adequate on the 1st Gen's, but do require frequent changes of the MC and the booster. Converting to Hydroboost will change your truck from night to day. I had read people reviews about the hydro boost being one of the best upgrades done to their truck, but once I did my own conversion I understand the praise of the braking system now!
Old Apr 1, 2019 | 07:10 AM
maybe368's Avatar
It is not uncommon, but it is common that the rear drums get out of adjustment and act like a bad booster. Make sure that the rear drums are correctly adjusted and that the automatic adjusters are working before you buy a booster...Mark
Old Apr 15, 2019 | 06:50 PM
fremec's Avatar
thanks to all you people for the info
robox
Sep 30, 2005 07:15 PM
sgT
Nov 30, 2004 01:54 PM
seedy1
Oct 20, 2004 10:50 AM
Crimedog
Oct 9, 2004 09:05 PM
betsycam
Aug 17, 2004 07:34 PM
