brake assist issues
Old Jun 16, 2011 | 01:44 PM
2hipsi's Avatar
brake assist issues
Ive got a 1st gen with the dual vacuum pump set up. When I apply the brakes to stop, the pedal drops about an inch out from under your foot, then gets stiff as a brick. The check valve tests good and the pump is pulling 22"s of vacuum.
I ended hooking a mechanical pump with gauge to the booster and hand pumped it to 20"s of vacuum. When I touched the pedal, the same thing happened. The pedal dropped and the vacuum was totally depleted in one press.
The booster was replaced about a year ago and I can't hear any hissing showing a vacuum leak. When I tested the booster with the vacuum pump, I left it sit for 10 minutes and no vacuum bled off. Soooo, with that being said, where should I look next?? RWAL valve??? Or the rod adjustment for the brakes??
Thanks
Old Jun 16, 2011 | 02:57 PM
Sounds like a bad booster regardless.
Old Jun 16, 2011 | 04:36 PM
2hipsi's Avatar
ok I'll give it a shot!
Old Jun 16, 2011 | 05:00 PM
maybe368's Avatar
Welcome back Faith......Mark
CascadeFirstGen
Sep 19, 2013 08:38 AM
Carpenter74
May 6, 2013 07:17 AM
pickleddiesel
Nov 25, 2007 04:29 PM
ET RAM
Dec 13, 2004 01:31 PM
sinner_0653
May 6, 2003 09:50 PM
