brake and abs light!!!!
Old Mar 25, 2006 | 04:22 PM
fjkfta's Avatar
Exclamation brake and abs light!!!!
i have a 93 w250 4x4. today i gave it wot and my brake light and abs light came on and it shuddered like it wanted to die. when i came to a stop the light went off. then when i went again normal throttle it came on again now its just on. but it only shuddered like it was going to die the one time. so my ? is were are the sensers or wiring that i need to look at. thanks any info is welcome. i will check back later i have a b-day party to go to.
Old Mar 25, 2006 | 04:33 PM
Not sure on the shuddering, it's doubtful that the two are related since the engine is all mechanical controlled.
Check the codes on the ABS and let us know what you find.
To check the codes: There's a little black plug by the parking brake release. Hook one end of a wire to a good ground, turn the key on, and momentarily touch the ground wire to the terminal in the black plug. The ABS light will start flashing. The pattern will be a long flash followed by a bunch of short flashes. Each long flash is the beginiing of a code. The number of flashes (including the long one) is the code number. Codes are numbered 2 through 15.
Old Mar 25, 2006 | 07:03 PM
fjkfta's Avatar
Thanks i will try and get back to you with the codes
Old Mar 25, 2006 | 08:02 PM
wreckere022002's Avatar
check you low vac switch on the l fender it is what the from the break check valve is running to on the finder also check out you booster mine shut down when it went bad just some ideas for ya
Old Mar 26, 2006 | 12:24 AM
fjkfta's Avatar
well i looked and dont see the plug. stupiod po probably cut it off. now i see my fuse box was wedgeed in there not mounted. ill post pics tommorow so you can have an idea what im talkin bout.
Old Mar 26, 2006 | 02:02 PM
Big Rich's Avatar
My lights come on as well, it only happens at lowest idle.
Rich
Old Mar 26, 2006 | 02:16 PM
Rich, yours sounds like low vacuum or a bad vacuum sensor.
Old Mar 26, 2006 | 05:34 PM
fjkfta's Avatar
well dave i found the prob. it seems this truck might have been stolen in its younger years, the steering console is broke on bottem so i pulled it off and walla another wirring nightmare. i cleaned up the wiring and works like a charm.
Old Mar 27, 2006 | 01:08 AM
dodge250's Avatar
my brake and abs light stay on all the time. ill check those codes and then post up. seems like only a few days after i bought the truck the lights would come on momentarily just in normal driving. now they stay on all the time.
Old Mar 27, 2006 | 02:31 AM
kerryneb's Avatar
my black wire was behind the glove box on my '92 (open the glove box all the way out). that's also where my abs computer is.
Old Mar 27, 2006 | 07:38 AM
Begle1's Avatar
I got my lights to go off accidently. It happened after the entire brake system was replaced, though, so I can't be too helpful.
I know that on mine the lights always come on when they need to be bled.
Old Mar 27, 2006 | 08:03 AM
flashgordon's Avatar
The wires from the frame rail to the speed sensor(on top of the rear alxle)are a common probem due to these wire constently flexing!
Old Mar 27, 2006 | 11:19 AM
marv406's Avatar
I had a similar problem and tried changing the abs sensor on the differential and that didn't fix it, mine was a bad wiring connector on the frame behind the gas tank. The dealer wouldn't take back the $87 dollar sensor because it had been installed. If anyone needs the sensor I'll sell it for half price or best offer, its still in the box, the only way you can tell its been installed is the orange coating on the o-ring is rubbed off in places.
Old Mar 27, 2006 | 04:54 PM
Ya have repaired a fue but min i remove the light bulb. don't like the way the rwal(rear will acuating brake system)brake system work Any ways!
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
