Bosch 40hp injectors?
Old 06-26-2013, 12:17 PM
Jordan5687's Avatar
I've been looking at replacing injectors because as far as I know these ones have 300k miles on these ones. A guy at a local shop is getting me a price on them. As far as I can see online tgeyre around $400. I'm trying to get as best mileage on my 93 as I can. Will this help my mileage, and how much do you think it'll help? I can't spend much, I gotta rebuild some front end stuff as well. Thanks.
Old 06-26-2013, 01:16 PM
93-12Smoke's Avatar
Larger injectors don't usually help fuel mileage. You may see an improvement if your old ones are just worn smooth out. What all is done to the truck? 4x4, auto or what?
Old 06-26-2013, 01:40 PM
Jordan5687's Avatar
Rebuilt 4 speed auto, 2wd. Engine runs and sounds good, I guess I can replace with just stock size. Guess cause it seems like it runs good ill just spend $ on the front end parts and new bushings.
Old 06-26-2013, 09:11 PM
d22019's Avatar
I would go back with stock injectors, they give the best fuel economy. I had a set of 4 hole +40's and I ended up hating them. They were smokey and got poor fuel mileage, basically like POD's with out the idle haze. They did boost the power up nicely but thats all.
Old 06-26-2013, 09:16 PM
93-12Smoke's Avatar
Spend the money on a better torque conv and you'll get better mpgs.
My philosophy on getting better fuel mileage is actually to make your power on air rather than fuel. Air is free!Better turbo and less restrictive intake piping.
I was getting 24mpgs with 33s but i also have a 5spd. If you can't afford a turbo make fueling adjustments on your pump. Best to do a turbo and ip tuning.
Old 06-26-2013, 11:05 PM
Jordan5687's Avatar
Ok, with that many miles on the injectors should I look at just stock replacement for the whole injector or just the nozzles? Yeah theres a hx35w on the truck. The intake is very free, just 4" tube 45 degrees to the side of the turbo with a big cone amsoil filter on it. Thanks for the great info. So what would be the best turbo for a pretty much stock truck besides pump mods? The injection pump has maybe 100 miles on the rebuild, tranny has a rebuild since 30k miles ago. We are hoping to push 24mpg out of it. With 3.55 on the rear, no locker I'm pretty sure. Might need to re gear or swap for a 3.07?
Old 06-26-2013, 11:09 PM
93-12Smoke's Avatar
I would do rebuilt stock injectors if you can afford it.
Old 06-26-2013, 11:24 PM
Jordan5687's Avatar
How much does that run? Cause the 40hp what I saw was the whole injector for under $400, should be less than that?
Old 06-26-2013, 11:40 PM
93-12Smoke's Avatar
Should be
Old 06-27-2013, 05:01 AM
KRB
KRB's Avatar
I just had mine cleaned and tested for about $120.
Old 06-27-2013, 08:37 AM
ClassA4x4's Avatar
Please tell us where you had this done. Thanks.
Old 06-27-2013, 03:12 PM
d22019's Avatar
Stick a gasket matched 16cm housing on that HX. Grinding mine out made it spool a little quicker. You don't really need the 12cm housing that the HX has with an auto.
Old 06-27-2013, 09:52 PM
Jordan5687's Avatar
I believe this is a 14cm housing but could be wrong.
Old 06-28-2013, 05:07 AM
KRB
KRB's Avatar
It was at a Louisville diesel shop. I'll have to find the receipt to see what the name was.
Old 06-28-2013, 06:30 AM
KRB
KRB's Avatar
Diesel Injection Service
4710 Almond Rd
Louisville, KY 40209
502 361-2531
Total was actually $142.17 and that included everything (banjos, gaskets, etc) for Bosch 190s.
Quick Reply: Bosch 40hp injectors?
