Borgeson steering shaft question
Old Sep 3, 2006 | 10:28 PM
gcliburn's Avatar
Smile Borgeson steering shaft question
I am considering installing a borgeson steering shaft. I was wondering if they work as well as everyone says. Also I noticed there is an extreme duty one that replaces the rag joint with a u joint as well. However I have not found any information from anyone who used one of these. The extreme duty shaft is only about ten bucks more at summit racing so the price is about the same as if you bought a new rag joint. I am wondering what is best and any input would be greatly appreciated. Thanks.
Old Sep 4, 2006 | 12:06 AM
hippie's Avatar
Man, I like mine. I got the heavy duty shaft. I would like to find a steering gear box stablizer. I had my front end rebuilt and all the brakes, and related parts replaced after 200,000 miles. The ole gril keeps going streight now. She stops real good too. I had the ABS removed, just have to be careful when I don't have the trailer on. If you get one go with the heavy duty. You can't go wrong with it.
Old Sep 4, 2006 | 10:30 AM
signkrazy's Avatar
Hi, I put a borgeson shaft on my truck a month ago. It is awesome!! I bought it off of ebay. That was the cheapest. I did have to get an alingnment done though. It steers better than new.
Old Sep 4, 2006 | 12:56 PM
gcliburn's Avatar
Is the heavy duty shaft much harder to put on since the rag joint has to come off?
Old Sep 4, 2006 | 01:07 PM
G1625S's Avatar
Check your steering shaft at the rag joint before you order. The HD unit is splined, and not all trucks have the splined shaft coming through the firewall...some have the bracket for the rag joint welded to the steering wheel side of the shaft.
Old Sep 4, 2006 | 01:54 PM
swank's Avatar
isn't there a way to just order the u-joints? make the shaft yourself? seems like i remember somebody doing the research on that. can't seem to find the thread though. i've been wanting to do that for a while.
dave
swhite832
Jan 30, 2007 11:13 PM
EricHeindel
Aug 16, 2006 01:24 PM
Dr.Kayak
May 18, 2006 05:32 PM
getblown5.9
May 9, 2006 05:34 PM
Raspy
Oct 31, 2003 01:17 PM
