Boost problems
Boost problems
I have a 1989 auto that i am assuming has original turbo just put a boost gauge on it today . Climbing a hill at full throtle i only made 17 lbs.Holding the brakes and full throttle i only made 4 lbs. Truck just does not seem to be making power
what do yall thing is wrong
The engine is probably lugging when power braking because of the tight converter. Do some pump mods and it will be a different animal. You should check the fuel pressure too if it still has the diaphragm pump. It will still run with a dead pump but zero fuel pressure and less power.
That's assuming the air filter is clear, the exhaust is reasonably free, and the turbo isn't screwed up.
