Boost gauge in. My #'s
Old Jul 27, 2006 | 10:24 PM
MoparMarv's Avatar
Well i put the boost gauge in tonight. Its an Isspro. At idle it sits at zero. normal acceleration about 5-7psi. hard in thrid 16-17psi. when I let off the throttle boost drops to zero. Does this sound right. I have the gauge on the dash for now so i can see what i get on the highway tomorrow. Do these #'s sound right for a stock truck? as far as I know nothing is turned up.
Old Jul 27, 2006 | 10:32 PM
gman07's Avatar
That sounds pretty normal to me. What year is your truck, auto/manual? They can vary in boost numbers from 14-20 or so stock depending on year and transmission (and other things, I'm sure).
Old Jul 27, 2006 | 10:36 PM
MoparMarv's Avatar
Its a 93 w250 Manual.
Old Jul 27, 2006 | 10:38 PM
gman07's Avatar
Yep, then it sounds about right. I'm pretty sure the earlier non-IC trucks ran more boost stock, but for a 93 your numbers sound right on.
Old Jul 27, 2006 | 10:42 PM
MoparMarv's Avatar
Zero at idle is right then? I'm ok with everything else. That was the only thing that didn't seem right too me. I figured so little bit 1-2 psi. I guess its time to start turning up the pump.
Old Jul 27, 2006 | 10:46 PM
gman07's Avatar
0 is perfectly normal for idle. You won't get boost unless the engine is loaded down somewhat. Even revving in neutral won't get you boost (unless you have a small turbine housing or retarded timing) because it isn't loading the engine.
Old Jul 27, 2006 | 11:59 PM
flashgordon's Avatar
my truck is a non intercooled truck and my guage is allso a isspro!
before the pump was turn up, the boost was 17-18. After pump turned up 22 and yes at idle our even at cruise with no load is 0.....ya i thought that there should be boost also but it is all normal!!!!
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
