Blower motor SURGES
Old Jul 7, 2012 | 10:50 PM
doug holt's Avatar
Blower motor SURGES
Hello, guys my blower motor sometimes blows hard then it will surge was wondering what would make it do that. Any help would be great. Thank you
Old Jul 8, 2012 | 01:13 AM
Jim Lane's Avatar
The brushes could be worn down and loose contact or the wiring could burning causing a bad connection worst case but probably just wearing out.
Jim
Old Jul 8, 2012 | 02:32 AM
doug holt's Avatar
I put new blower motor on I figure it could be connections are just wore out thank you for your time
Old Jul 8, 2012 | 06:22 AM
Jim Lane's Avatar
If you already replaced the blower motor then it must be in one of the connections,
Drop down your fuse panel and have a look at Fuse #1 it is a 30-amp Fuse and see if it is melted,
then turn it around and check the wiring side, also check the condition of the connector at the blower motor itself.
How many volts do you have at the blower motor on High?
The blower circuit is a known weak link in the truck wiring, and will eventually melt the wiring under your steering column and destroy your ignition switch causing you countless hours of frustration.
Here is the wiring diagram.
The fix.
https://www.dieseltruckresource.com/...d.php?t=158400
Jim
Jim Lane
Apr 5, 2020 06:03 AM
RedRocket
May 21, 2004 01:28 PM
Jones0027
13
Dec 18, 2003 01:10 PM
Copenhagenjunkie
Jun 1, 2003 04:20 PM
