blocking off heater core for summer
It seems that my factory vacuum operated shut off valve is eithe. Broken inside or just doesn't seal anymore. The vacuum is working fine but I still get a reduction in a/c output. (Surface of evaporator is 34/35 degrees but panel temps never fall below 55-60)
What I would like to know is if I can install a manual shut off to block 100% of flow to the heater core? I don't know if the factory vacuum operated valve was ever designed to block flow 100% or if it was meant to flow a little bit for thermostat bypass reasons. Any input would be appreciate.
I installed manual shut off valve on my motor as well. Check out post #707 in my build thread....
https://www.dieseltruckresource.com/...8/#post3250003
Indiana0331
Jun 28, 2012 04:17 PM
canadakonrad
Dec 1, 2010 08:41 PM
wdimig
Sep 29, 2010 07:38 PM
