Big o
Old Apr 14, 2013 | 02:41 PM
bannerd's Avatar
Big o
Hey all my ip is leaking from the large oring. I just rebuilt my pump not too long ago and the oring was green. I ordered another kit an put it on again and it seemed fine. I noticed it started to drip again.
I can see air sucking in where it splits between the block and main pump. Should I order another kit? I thought about tightening the Allen bolts but I don't want to snap them. If I recall the orange sits inside and tightening it wouldn't help much. Strange I put 2k on the pump with no leaks.
Old Apr 14, 2013 | 06:17 PM
The big O-ring on the head? This one can be a little trick to get in place without damaging it. When you replaced it was there any damage to the old O-ring?
Old Apr 14, 2013 | 06:22 PM
bannerd's Avatar
Yeah the big o ring on the high pressure lines. It was fine looking when I took it off. Figured it might have been a design flaw. Nope.
Old Apr 14, 2013 | 06:24 PM
bannerd's Avatar
Strange it sucked in some motor oil I put on it.
Old Apr 14, 2013 | 08:44 PM
They can sometimes fish mouth and not have a good seal. I usually take a lot of time lubing the O-ring, then carefully tightening the head down. I watch the O-ring and push it in with a smooth rounded end pick.
Old Apr 16, 2013 | 01:28 PM
bannerd's Avatar
What size hex goes into the back of the pump? Friend of mine is going to pick it up tomorrow. I was thinking a 6mm?
Old Apr 16, 2013 | 01:46 PM
I want to say it's an odd size...like 6.5mm?
Old Apr 19, 2013 | 06:34 AM
bannerd's Avatar
It's a torx bit 5mm, it isn't the O-ring. Took the lines off last night and I had a high pressure port leaking. I took it out and it looks like the copper washer was in backwards. The flat side was to the nozzle port and the ridged side was to the oring block. I flipper it over and I don't see anything leaking now. Thinking when I rebuilt the pump I must have put it in upside down
Old Apr 19, 2013 | 07:46 AM
Smokin$$away's Avatar
So many little things to go wrong. PITA to have all these little parts that can baldheadedness. Glad you figured it out bannerd.
JSCumms2000
20
May 6, 2007 02:14 PM
Mexstan
Sep 16, 2006 05:29 PM
boiler-rat
Jan 16, 2006 03:11 PM
Dieseldude4x4
Oct 17, 2004 11:07 PM
Shaders 24v
Aug 11, 2003 10:18 AM
