best turbo for towing
Old Dec 20, 2009 | 09:53 AM
adam greene's Avatar
what would be the best turbo for towing my truck is a 93 d-350 few little pump mods everything else stock.
Old Dec 20, 2009 | 11:06 AM
Auto or stick?
Old Dec 20, 2009 | 11:13 AM
Falcon1's Avatar
I like my 35/40 hybird and I tow with an auto,,,,, that's broke right now
Old Dec 20, 2009 | 11:41 AM
cougar's Avatar
If you keep things mild, you can hybrid your H1C to 60mm for around $225. That is what I am doing to my 91 as soon as I can sneak it into the hangar.
Old Dec 20, 2009 | 12:12 PM
Get a torque converter first.....turbo wont do much good besides cool EGT's
Old Dec 20, 2009 | 03:11 PM
its a auto, i plan on gettin a tq. how do i change mine to a 60mm would that give any more power. what about a turbo off a 24v
Old Dec 20, 2009 | 03:15 PM
The turbo you have will work just fine with your stock injectors. As long as you have enough air to burn your fuel, a different turbo will not add more power. On a diesel, fuel=power. You need enough air to burn the fuel and keep EGT down. If EGT's are high then upgrade to the 60 mm compressor. See the sticky for how.
Old Dec 21, 2009 | 01:31 AM
Crazy Matt's Avatar
Id see what ur budget is and then buy a turbo according to what it says and how many mods you want in the future.
HE 351 would be a good upgrade if ya wanna keep it cheap.
Old Dec 21, 2009 | 10:45 AM
cougar's Avatar
What do you have to change to make the HE 351 work?
Old Dec 21, 2009 | 12:59 PM
92smokin blacky's Avatar
to get the he351 to work, you just gotta reclock the housings and pull the two studs out of the turbo and drill the holes a little bigger and then it'll bolt right up. You don't have to reclock the housings, but then you have your intercooler pipe up on top and have to make it go over the intake tube. If you reclock the housings, you'll have to take the wastegate off, but i made a bracket with a spring so my wastegate will still open off of drive pressure at about 34 lbs, if i take the spring off and put a turnbuckle on it so it will stay shut, i can hit 40 lbs.
I really love this turbo and it cools really well and spools really quick, my trucks an auto and i love it
Old Dec 24, 2009 | 11:19 AM
cougar's Avatar
Do you have to change the exhaust, or will the stock exhaust still fit?
Old Dec 24, 2009 | 03:56 PM
the he351 has a 4" exhaust outlet so you will need a 4" system if you don't already, and then you'll just have to weld the flange on to the downpipe and use a V-band clamp.
I have a hood stack so i just have a 4" 90 elbow welded to the 4" he351 flange v-band clamped to the turbo, with a 5" tip on the 4" elbow.
deerslayer1979
Feb 9, 2010 01:02 PM
cvcook
Jul 20, 2008 05:40 PM
whereswaldo250
Nov 15, 2007 12:38 PM
rstone
Nov 13, 2007 11:07 AM
Syndicate
15
Feb 1, 2006 02:45 PM
