best intercooler upgrade options
Old Sep 4, 2010 | 03:48 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
When I put my S300 on, I'm worried my 2.5" inlet/outlet on my factory intercooler will be a restriction. I know folks use Powerstroke I/C's, what's the benifet of those price? Who else has performance/ 3" I/C's? I think banks has one.
Thanks
Old Sep 4, 2010 | 03:54 PM
MoPowa's Avatar
Well in my opinion you sure can't beat the price of the powerstroke intercooler. I found one for 150 and paid 15 dollars for silicone boots, other than that a couple hours of messing around and modifying it to fit there is basically no other cost. I'm sure you could find something roughly the same size as our stock intercoolers with a 3 inch id, but you wont get the same cooling as a larger intercooler. A second or third gen intercooler takes a little bit more fabrication to put in from my understanding as well.
Old Sep 4, 2010 | 03:59 PM
#2isgreen's Avatar
Is a P/S 3"?
Old Sep 4, 2010 | 04:08 PM
92smokin blacky's Avatar
I paid $125 for nice PS intercooler with no leaks or bends from a salvage yard and got the boots and clamps with it. I just had to clean it up good. Yes it is 3" and it think they have a better "necks" to them than the 2nd gen intercooler it looks like to me, the 2nd gen ones would be a little more restrictive.
Old Sep 4, 2010 | 05:47 PM
#2isgreen's Avatar
Great thanks. Should I try to re-use the stock PS boots? If they come with the IC. I got a buddy building up his F-350 and he's got his stock IC laying around in the garage.
Old Sep 4, 2010 | 07:08 PM
Montana2x2's Avatar
Make sure you get the one with the aluminium tanks not the plastic.
Old Sep 4, 2010 | 10:13 PM
yep off an 99-01 powerchoke if i remember right. I'd go ahead and try and get the boots. I coulda used the ones i got with my 3" coolertubz but had 2' of red silicone tubing instead.
Old Sep 4, 2010 | 11:14 PM
jimbo486's Avatar
Powerstroke i/c's are 3.25" so you'll need reducer boots to run 3" tubes.
Old Sep 5, 2010 | 09:11 AM
#2isgreen's Avatar
This is great thanks eberybody. Where should I look for good reducer boots that can handle lots of boost.
Also are the PS I/C's any better at cooling or do they just flow better. Should I expect a 100 deg drop in egt?
Old Sep 5, 2010 | 01:16 PM
jimbo486's Avatar
I've been buying my stuff at www.siliconeintakes.com. They have good prices and, in my opinion, the quality of their product is very good!!
Old Sep 5, 2010 | 07:33 PM
3" silicone will fit over the 3.25" Powerstroker intercooler ends, it worked for me, a little tighter but in my mind i'd rather have them tight cuz they won't want to blow off as easy. I just ordered 2' of 3" silicone straight tubing and then cut 6" to 8" pieces out and used them with my 3" piping and still had some left in case i ever blow a boot in the future, I'll have an extra or two. I ordered mine from www.frozenboost.com, but it looks like they have about the same stuff and same prices.
dstad
Apr 24, 2009 10:03 PM
dieselcarpenter
Dec 3, 2007 05:37 AM
Ocmechanx
Feb 20, 2007 11:01 AM
DodgeDawg2500
Feb 17, 2006 12:08 PM
sammy340
Jun 23, 2005 08:31 PM
