Banjo Bolt Explained
You mean the one that connects to the return line? That is a Bosch part with a flow restriction in it. A regular banjo bolt will thread in but the pump will not build case pressure and it will run like dog doo.
The best thing that I did to the banjos on my Ford/Cummins was to replace them with JIC adapters, JIC swivels, and rubber hose.
No longer is it a dreaded fight to service a lift-pump and the nature of rubber lines allows un-limited little gadgets and conveniences to be added, removed, and experimented with.
