Bahf mounting trouble help
Old Feb 26, 2009 | 01:59 PM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
i built the old smokey bahf today went to mount and found that i need to relocate the radiator over flow is that true on a 1990 non I/C or did i do something wrong?????
Old Feb 26, 2009 | 08:05 PM
justin mcfall's Avatar
It is a pain,but when i had mine,just remove the overflow tank,mount the BHAF,then put the tank back on. It is only 3 screws. Hope this helps. Justin
Old Feb 26, 2009 | 09:24 PM
thanks i am doin it now
Old Feb 26, 2009 | 09:48 PM
No problem...
Old Feb 27, 2009 | 02:59 AM
well got it in but the tank wont fit mowed it to the driver side fender behind the batt. will that work there??
and broke the fitting off the radiator where the line connects
have to sodder in the mornin any suggestions instead of sodder (jb weld) maby????
Old Feb 27, 2009 | 07:53 AM
Rickcher's Avatar
Try Marine Tex. You can get it at Ace Hardware or a boating supply store. Much better than JB Weld.
branhay
Nov 20, 2005 11:01 AM
branhay
Nov 13, 2005 10:34 AM
surfer5567
Nov 7, 2005 04:59 PM
DODGE4X4
33
Feb 21, 2005 02:54 PM
DodgeRulzes
Dec 12, 2004 12:06 AM
