Bahf
Old Dec 7, 2004 | 03:58 PM
DodgeRulzes's Avatar
Bahf
I did did the BHAF install. I used the big duralite filter. I also mounted the filter minder in the first rubber elbow. The only worries me is as soon I drive it a few miles the filter minder is pulled all the way in. On the stock set up the filter minder never moved. My question is, with this setup is there more restriction? Buy the way, I can hear the tubo now.
2004.5 Black 600 Crew cab
Old Dec 7, 2004 | 04:30 PM
Dodgezilla's Avatar
My filter minder is in the garbage..
Old Dec 7, 2004 | 05:30 PM
cumminsboy's Avatar
We don't need no stinkin' filterminder!!!
Old Dec 7, 2004 | 07:04 PM
surfram's Avatar
Does anyone make a BHAF kit for 3rd gens?
Old Dec 8, 2004 | 04:42 AM
Dodgezilla's Avatar
You have to make it yourself. If you want the ultimate BHAF do a search on BHAF. There is one topic, in particular, started by AKRAM, that has about 20 pages. Close to the last page he lists all the parts he used to make his system which is the best I've seen. Mine's simple, pull the air box, install rubber elbow over end of filter, drill hole for air sensor, put tie wrap over sensor so it stays put, tie wrap old floormat under BHAF to lessen waterspray, and stuff filter down in the hole.. Done! I am awaiting some new parts from Air Flow Systems, which is where AKRAM got most of his parts, to do some finishing touches on mine..
Good luck and check my gallery....
Oh ya! Don't forget the Outerwears prefilter....
Old Dec 8, 2004 | 03:59 PM
nickleinonen's Avatar
it depends on the position of the filter minder. if you have it in a spot where you get high velosity across the end, you can build low pressure in the minder
[take a straw and glass of water. put the straw in the water and blow across the end of the straw. if you do it just right, you will get water to come up the straw...]
Old Dec 8, 2004 | 07:04 PM
Turbo Deeezle's Avatar
Oh....simple one...... just do what I did
Put the filterminder back on the stock airbox and put it on a shelf in the garage
Old Dec 12, 2004 | 12:06 AM
Fordzilla's Avatar
That would be this one ...Ben
branhay
Nov 20, 2005 11:01 AM
branhay
Nov 13, 2005 10:34 AM
surfer5567
Nov 7, 2005 04:59 PM
DODGE4X4
33
Feb 21, 2005 02:54 PM
