bad computer? help
Old Jun 26, 2017 | 03:07 PM
bigredodge's Avatar
bad computer? help
not working: over drive, speedo, odometer, no charge, ac clutch (probably not related..PROBABLY) only works with direct wiring to bat.
I thought my problem was the wiring harness to transmission (od solenoid, speed sensor, thermal od lockout) all rodent chewed and melted, made a new wiring harness for it all didn't fix any of my problems except it went from blowing ignition fuse and no start, to start and drives.
I have checked crank position sensor (not sure if I did it right) by, key off, probing power from pcm wire-dead, sensor return wire-.04 volts.
truck running yielded same results.
forgot to mention I tested the speed sensor and nothing, replaced it with a new one didn't fix anything so I tested it with a drill still nothing.
so I have ruled out CPS(probably), speed sensor( for sure) and bad wiring (all tape off went through entire wiring harness while fixing trans wiring).
ok so my conclusion is that my pcm is bad. please tell me I'm wrong
thanks in advance
oh yeah checked the remaining fusible links, all passing voltage no cracks tears burns etc. all is good there
Old Jun 26, 2017 | 03:45 PM
bigredodge's Avatar
well I think I fixed it and I was half right. dug in further to the computer wiring found a red wire (directly to bat according to wiring diagram) it was spliced together with a similar sized red wire from the start relay and tucked up behind the fender... no idea how any of this worked up until this point after seeing that... now I have to figure out where the red relay wire is supposed to be. first I'll test drive to make sure I have speedo etc.
Old Jun 26, 2017 | 09:26 PM
bigredodge's Avatar
good to go
yep that one wire broke the whole truck, got it rigged on my headlight breaker for now. even fixed my ac!
Old Jun 26, 2017 | 09:30 PM
maybe368's Avatar
That's great! Glad we could help ...Mark
Old Jun 26, 2017 | 11:41 PM
j_martin's Avatar
You've got a million mile motor in a 150,000 mile body with a 30.000 mile wiring harness.
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
boomer
Nov 28, 2005 07:58 PM
C Pierce
Mar 21, 2005 08:41 AM
04 SO CA
Apr 25, 2004 07:27 PM
