Checking for codes bad for computer?
Old Apr 23, 2004 | 10:42 PM
04 SO CA's Avatar
After engine light went on (and then off after about five starts) I'm getting a code when I check for codes with on off key procedure. P-1757. Dealer says that no codes come up with their scan tool and that cycling the ignition like that may have damaged the computer. That's news to me. Anyone heard of this?
Thanks...Rick
Old Apr 24, 2004 | 12:03 PM
mymaur's Avatar
Re: Checking for codes bad for computer?
Thanks...Rick
Try another dealer. Sounds like a bit of hooey.
Old Apr 24, 2004 | 03:14 PM
04 SO CA's Avatar
Sounds like it to me too. Can't imagine that DC would equip our trucks with this function if it was a NO NO to do. Next stop another dealer. Thanks mymar.
Old Apr 24, 2004 | 08:50 PM
800summit's Avatar
Try pushing the trip button the turn the key to the on position then release the button, should give you all the stored codes
Old Apr 24, 2004 | 10:06 PM
04 SO CA's Avatar
Using the trip technique also shows stored codes?
Old Apr 25, 2004 | 04:38 PM
Tom488's Avatar
No, holding the trip reset while turning the key will show you the instrument cluster codes. These are NOT the same as the OBD-II powertrain codes. Powertrain codes are displayed by cycling the ignition key three times.
Old Apr 25, 2004 | 07:27 PM
04 SO CA's Avatar
That's what I thought. Thanks guys. Can't imagine it would be harmful to do.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tacohat
Jul 17, 2006 02:27 PM
DarrellB
Sep 6, 2003 04:49 PM
