Auto Transmission Question
Old Jul 21, 2008 | 06:08 AM
JD730's Avatar
Originally Posted by txdlvryman
1st , 2nd , and 3 rd shift fine,, It just shifts into overdrive early, and if you lift off the accelerator and coast , it kicks out of overdrive.. Put your foot back on the accelerator and it shifts back to overdrive.. It wont kick out unless you lift of the pedal...
Deffinately the TPS, its either dirty or just plain worn out. Time for an alternate solution, potentiometer mod, manual switch, or a new TPS.
Originally Posted by keith1992
Couldn't this also have to do with that kick down thing with the little spring by the IP pump?
Nope, that is the throttle valve cable and has nothing to do with overdrive function. It increases the line pressure of the trans as you give it more throttle, affects the first 3 gears.
Old Jul 21, 2008 | 12:30 PM
unixcowboy's Avatar
Boy does it ever...
Mine was kinda sliding into 2nd and 3rd.
I put a bolt and nut into the TV slot and adjusted the cable so that wot would push the tv cable ALL the way to the stop.
Now she SHIFTS into gear...
Only prob is she holds the gears longer - 1st = ~ 18, 2nd = ~ 28, OD = ~ 38.
On the other hand the engine doesn't lug as much and I believe my mileage is up ~ 1 mpg in town.
I think I'll really see an improvement when I get the 47RH in and get it adjusted.
I'm not sure if I want to lock up in 3rd or wait until OD...I'll wait and see how and at what speeds it shifts normally before I set the lock up speed.
kit
Mar 2, 2010 07:04 PM
Alan88
Dec 26, 2009 08:44 AM
bobsallyh
Oct 28, 2008 07:06 PM
Pike
Jul 16, 2007 02:17 PM
Larryb01
Oct 13, 2005 06:40 PM
