Auto transmission question
Old Jul 16, 2007 | 05:53 AM
Pike's Avatar
Will an automatic from a 94 bolt up to a 99?
Thanks
Old Jul 16, 2007 | 09:17 AM
gmctd's Avatar
Yes it will bolt up, BUT - the '94 47RH has a mechanical governor - the '96-up has electric governor, controlled by the ECM - prolly cause a bunch of ECM DTC's - if you're installing in a manual truck, the RH would be easiest swapout - if you want ECM to control TCC and shifting pressures to match engine output, then go for the RE, add the corresponding ECM and harnesses
Old Jul 16, 2007 | 02:17 PM
Pike's Avatar
Thank you. I was talking auto-auto.
kit
Mar 2, 2010 07:04 PM
Alan88
Dec 26, 2009 08:44 AM
bobsallyh
Oct 28, 2008 07:06 PM
txdlvryman
Jul 21, 2008 12:30 PM
Larryb01
Oct 13, 2005 06:40 PM
