auto tranny swaps
Old Jul 2, 2003 | 11:11 PM
apache's Avatar
auto tranny swaps
Ive been told by several HD truck shops that you can readilly find an Allison 5 speed trans from a bus or other rig to bolt up to the CTD. Obviously some fabrication would be needed, driveline, linkage, bla bla bla. anyone done this yet???
Old Jul 3, 2003 | 11:45 AM
ramguy's Avatar
Re:auto tranny swaps
Apache;<br> I looked into the same senario, the problem is cooling. The Alison needs a larger cooler than our stock cooler. :'(<br> What I learned was that there really isn't enough room w/ a innercooler, &amp; A/C condencer.<br> I also have a 93, after speaking w/ several folks at different<br>bussiness, Tranny shops, ect. &amp; the good folks here on DTR. ;D<br>I choose to convert to a lock-up TC, and trans. one of the benifits of this trans set up is much lower opperating temps. ;D<br> I'm working on a story w/ photos &quot;to air on this site w/ OK from Mr. Thorpe&quot; that will describe in detail how to make the conversion. The tranny I installed is a 94-95 model 47RH. ATS built extreem duty w/ tripple lock TC, is the best upgrade I could have done, the power gets to the ground. ;D ;D<br><br> ramguy <br>
Old Jul 3, 2003 | 03:16 PM
apache's Avatar
not to be to prying, but what might one be lookin at $$$ wise for this type of set up.<br> Thanks. Apache
Old Jul 4, 2003 | 09:49 AM
Stevie G's Avatar
Details brother, details!!<br>What shifter did you use?<br>What changes (IF any) as far as wiring?<br>Do you tow?<br>
Old Jul 4, 2003 | 01:32 PM
ramguy's Avatar
Apache;<br> Let me say this 1st I was looking at the 03's and the price wasn't the worst part :'( but $650/year for a tag vs the $130 for 93 helped in my decision and the fact that my ctd also is just broke in at 174k mi. ;D<br> Any how the conversion ran about $5,800., but I think it was worth end result. With a little small amount of BOMBING<br>this puppy's gonna pull anything I need and run efficiantly while doing so. ;D
Old Jul 4, 2003 | 08:08 PM
dfeland's Avatar
Just for FYI I have an adapter plate the is required to go from a non-lock up trans(a-518) to a lock up trans. If anyone is interested I would make them a good deal. Thanx
Old Jul 4, 2003 | 11:34 PM
Stevie G's Avatar
What's different?<br>I thought the bellhousings were the same?<br>I know they use the same flex-plate (Later one is better)
Old Jul 5, 2003 | 02:44 PM
dfeland's Avatar
Because the lock-up convertor is wider it sticks out of the trans therefore the adapter plate is deeper to accomodate the wider convertor.
Old Jul 5, 2003 | 09:38 PM
Stevie G's Avatar
I'll have to take one of my 24 valve adapters with me to Ft Walton beach then, Huh?<br>Glad I started stocking up on this stuff.
Dr. Evil
16
May 9, 2008 03:10 PM
bigragu
Sep 29, 2007 03:06 PM
DodgeRamdiese01
Sep 7, 2007 08:00 PM
Spencnaz
Sep 25, 2003 08:36 PM
Superduty12v
Jul 24, 2003 12:41 PM
