ATF Level
Old Mar 11, 2006 | 04:08 PM
Blowndodge's Avatar
ATF Level
I'm assuming I'm checking the fluid level correctly. I think it severely overfilled! When fully warm and engine running and in Neutral, the level reads all the way up past the S bend, which is about an inch and a half above the upper dot. I'm I checking it correctly? I have the extra under bed auxillary cooler from the factor installed too.
thanks,
brad
Old Mar 11, 2006 | 09:26 PM
Sounds like you are doing it right. The book says that "hot" means you can't hold the oil between your fingers, and it is to be checked in neutral. Time to dump the excess.
Old Mar 11, 2006 | 10:58 PM
Blowndodge's Avatar
Thanks Dave! Think I'll dump half and bring it up to nomal "between the dots" with type F and see if I get firmer shifts with 50/50 mix of +3 & F
brad
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
teckert
Jun 9, 2004 12:34 PM
