Archived threads
Old Oct 30, 2017 | 01:53 PM
maybe368's Avatar
Archived threads
I thought that if there was a failure where the sticky threads cannot be accessed, that a thread with a list of archived threads may be useful. If the mods have a problem with this, please feel free to delete it. I am sitting in Mexico right now and there is some down time, so I am going to try to archive all of the sticky threads, so that they will be preserved for a looooong time. ...Mark P.S. I intend to do them all, I just started with mine...
Old Oct 30, 2017 | 02:01 PM
maybe368's Avatar
General Information:
Basic specs for the 1st gen engine (along with some part #'s):
https://web.archive.org/web/20171030...s/91specs.html
Fluid capacities:
https://web.archive.org/web/20171030...y-id-s-204044/
Model names explained (even I couldn't find a clear explanation doing a search ): Our trucks are all 250 (3/4 ton) or 350 (1 ton) rated. D-series trucks are 2wd, W series trucks are 4X4's. D350 = 2wd 1 ton.
Technical service bulletins:
https://web.archive.org/web/20171030...letins-315813/
Misc. part #'s:
https://web.archive.org/web/20171030...n&onlynewfaq=1
More part #'s:
https://web.archive.org/web/20171031...umbers-164612/
Part Number changes and Special Notes:
https://web.archive.org/web/20171030...thread-308871/
2nd Gen wheels on a 1st Gen:
https://web.archive.org/web/20171030...st-gen-147764/
3rd Gen wheel on a 1st Gen:
https://web.archive.org/web/20171030...d-know-255446/
Block heater outlet install:
https://web.archive.org/web/20171030...rticle-167831/
How to post pics on DTR:
https://web.archive.org/web/20171030...forums-187910/
Old Oct 30, 2017 | 02:07 PM
maybe368's Avatar
Body
Body:
Glove Box LED Upgrade:
https://web.archive.org/web/20171030...pgrade-316712/
Replace your ignition lock cylinder or ignition switch (Tilt column):
https://web.archive.org/web/20171030...linder-241339/
Replace The Ignition Key Lock Cylinder On Non-Tilt Wheel:
https://web.archive.org/web/20170702...-wheel-312883/
A Look Inside Your Power Mirrors:
https://web.archive.org/web/20171030...mirror-300928/
Cowl crack fixes:
https://web.archive.org/web/20171030.../wiki/Cowl_Fix
Commence Operation Silence: (How to insulate and soundproof your cab):
https://web.archive.org/web/20171030...ilence-287033/
Door latch/handle repairs:
https://web.archive.org/web/20171030...iew;article=41
Floppy mirrors?
https://web.archive.org/web/20171030...iew;article=63
Window motor repair (also covers R&R):
https://web.archive.org/web/20171030...-motor-100536/
Window motor repair revisited - circuit breaker and brush replacement:
https://web.archive.org/web/20171030...inside-141605/
Drilling crank window doors for power windows:
https://web.archive.org/web/20171030...ersion-211811/
Tailgate latch repair:
https://web.archive.org/web/20171030...iew;article=72
Clean out the HVAC box:
https://web.archive.org/web/20171030...iew;article=57
Clean out the HVAC box (with unique lid):
https://web.archive.org/web/20171030...-twist-298318/
Removing the HVAC box (to change heater core or evaporator):
Let's replace our wing window seals and how to remove the wing window assembly:
https://web.archive.org/web/20171030...ac-box-248580/
Converting A/C to R134a:
https://web.archive.org/web/20171030...advice-107810/
Renew your AC system:
https://web.archive.org/web/20171030...system-313221/
Body/patch panel sources:
https://web.archive.org/web/20171030...dge_pickup.htm
Poly Cab mount bushings:
https://web.archive.org/web/20171030...shings-217491/
Gauge cluster refresh:
https://web.archive.org/web/20171030...Gauge_Cluster/
Odometer repair:
https://web.archive.org/web/20171030...r-long-128685/
Alternate source for odometer repair parts:
https://web.archive.org/web/20171030...option-185945/
Repairing gauge cluster lights:
https://web.archive.org/web/20171030...repair-265366/
2nd/3rd gen towing mirrors:
https://web.archive.org/web/20171030...n-pics-150798/
https://web.archive.org/web/20171030...-seals-313519/
Replace your door and window weatherstripping:
https://web.archive.org/web/20171030...g-door-152939/
An insider's view of the doors courtesy of Jim Lane: With Part Numbers:
https://web.archive.org/web/20171030...-doors-218946/
Emergency hood release cable install:
https://web.archive.org/web/20171030...elease-187435/
How To Secure Your Tailgate:
Fix your vent window latch:
https://web.archive.org/web/20171030...-latch-191213/
How the speedometer drive works:
https://web.archive.org/web/20171030...-works-198123/
Make your own interior shelf:
https://web.archive.org/web/20171030...-shelf-219993/
Replace your saggy headliner:
https://web.archive.org/web/20171030...rs-out-186450/
Water on the driver's side floor?
https://web.archive.org/web/20171030...ng-wet-264729/
2nd gen seats:
https://web.archive.org/web/20171030...finish-276849/
Seat Heaters:
https://web.archive.org/web/20171030...s-pics-284720/
Wiper-Arm Bushings:
https://web.archive.org/web/20171031...shings-282912/
Old Oct 30, 2017 | 02:11 PM
maybe368's Avatar
Brakes
Brakes:
Properly adjust your rear brakes:
https://web.archive.org/web/20171031...ctures-207170/
1 ton shoe conversion:
https://web.archive.org/web/20171031...-brakes-63137/
ABS diagnostic:
https://web.archive.org//web/2017103...s-part2-59092/
Drum removal - also includes disc brake conversion (this is a D60, so don't take the conversion info as gospel - and none of the conversion kits work on duallys):
https://web.archive.org/web/20171031...iew;article=10
Rear disc conversions:
https://web.archive.org/web/20171031...ersion-146673/
4X4 front wheel bearing and brake service:
https://web.archive.org/web/20171031...eneral-143024/
2wd front brake service and proper pad installation technique:
https://web.archive.org/web/20171031...-noise-248986/
2WD Front Disc Brake Repair and Upgrade, Pt1
https://web.archive.org/web/20171031...de-pt1-309731/
Where do I get a front hub nut socket that fits?
https://web.archive.org/web/20171031...am-nut-197880/
Fixing a grooved spindle without a speedi-sleeve:
https://web.archive.org/web/20171031...native-145733/
Fixing a grooved spindle with a speedi-sleeve (for when you've worn 2 grooves in it ):
https://web.archive.org/web/20171031...e-seal-229470/
Rear hub service:
ttps://web.archive.org/web/20171031015614/https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/service-your-rear-bearings-seals-148798/
Braided stainless brake hose install:
https://web.archive.org/web/20171031...-hoses-150248/
Booster replacement:
https://web.archive.org/web/20171031...nstall-223789/
Adjust and repair the P-brake pedal:
https://web.archive.org/web/20171030...-pedal-326280/
Old Oct 30, 2017 | 02:15 PM
maybe368's Avatar
Steering and Suspension
Steering and suspension:
Dually wheel centering procedure - mandatory reading for all dually owners!
https://web.archive.org/web/20171031...wheels-248980/
2wd levelling (raise front end):
https://web.archive.org/web/20171031...ed-week-93841/
https://web.archive.org/web/20171031...-dodge-217632/
2wd ball joints (also covers bearing service):
https://web.archive.org/web/20171031...e-pics-265538/
Steering coupler rebuild:
https://web.archive.org/web/20171031...iew;article=85
Borgeson shaft install:
https://web.archive.org/web/20171031...iew;article=96
Another one on the Borgeson with instructions on changing the input shaft seal:
https://web.archive.org/web/20171031...-100582/page2/
Important note on steering shaft replacement: DO NOT spin the steering wheel with the shaft disconnected. Some of these trucks use a clockspring to run the horn and cruise, break it and it's about $150 to fix it. Tie the steering wheel to the seat frame before you disconnect the shaft.
Homebrew steering shaft:
https://web.archive.org/web/20171031...teering-93363/
Steering box bracket P/N:
https://web.archive.org/web/20171031...racket-125939/
Input shaft seal replacement:
https://web.archive.org/web/20171031...iew;article=15
Crunching/scraping noise inside the steering column?
https://web.archive.org/web/20171031...column-182442/
Add polyurethane spring tip bushings to improve your ride:
https://web.archive.org/web/20171031...nserts-224332/
Build new rear shock mounts (think Dana 80 or 3 bearing 14 bolt swap )
https://web.archive.org/web/20171031...mounts-212944/
Quick and dirty steering box adjustment - for a Jeep XJ but our box works the same way:
https://web.archive.org/web/20171031...ent-20047.html
Wheel hop fix -advanced fab skills required:
https://web.archive.org/web/20171031...-links-274327/
Replace/Renew DANA 60 4x4 king pins & seals:
https://web.archive.org/web/20170702...g-pins-290373/
Crossover Steering:
https://web.archive.org/web/20171031...2-lift-291427/
Steering Gear Retrofit:
https://web.archive.org/web/20171031...y-92-a-301769/
Steering Coupler protector:
https://web.archive.org/web/20171031...tector-303388/
Old Oct 30, 2017 | 02:16 PM
maybe368's Avatar
Electrical
The Importance of Alternator Grounding (Explains why your lights dim when it is cold:
http://web.archive.org/web/201711010...ground-297761/
It's not charging! ('92 & '93 trucks only):
http://web.archive.org/web/201711010...charge-252750/
What are all these wires doing on my mechanical engine?
(non-intercooled):
http://web.archive.org/web/201711010...ersion-130793/
Help me ID these - pics inside - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711010...inside-128911/
Headlight relays:
Installing Headlamp Relays - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711010...iew;article=46
RamchargerCentral.Com - Articles - How to Install Headlight Relays - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram:
Headlights no longer suck! - Dodge Diesel - Diesel Truck Resource Forums Shows how to have low beams on with the high beams:
http://web.archive.org/web/201711010...er-suck-74442/
Grid heater relay repair:
Denis Hruza - Dodge CTD - Grid Heater Solenoid Tune-Up:
http://web.archive.org/web/201711010...Heater_Relays/
91.5 wiring diagrams
Index of /Dodge_CTD/1991.5-Wiring_Diagrams
http://web.archive.org/web/201711010...ring_Diagrams/
LED cab light conversion (now with light location diagram for new installs:
Update 1st. Gen to the 21st century - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...entury-100449/
LED turn signals and taillights:
LED turn and tail lights. - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...lights-166797/
How To Install LED Front Turn Signals (front corner lights will flash properly:
How to install Front LED Turn Signals - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...ignals-287930/
Another LED Taillight Install:
Make your own LED taillights.. (enhanced Taillight version) - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...ersion-297319/
'92 and '93 PCM power check:
The TPS & CPS/PCM VR Bypass Challenge. - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...llenge-114285/
Converting the stock alternator to internal regulation:
NipponDenso Alternator Regulator - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...ulator-148984/
Leece-Neville alternator install:
Leece Neville Alternator on a 6BT Cummins - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711011...ummins-247286/
Install a Start Stop Switch
How to install a Start & Stop switch. - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...switch-197607/
Brake Light Switch Repair
Brake Light Switch Repair - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...repair-289938/
Rebuild your starter:
Rebuild Your CTD Starter - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...tarter-141395/
Replacing fusible links with fuses:
Fusible Link Abatement Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...tement-135504/
Adding a power distribution center:
Trailer lights isolation - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711011...lation-273614/
Put your blower motor on relays:
Blower motor - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...-motor-158400/
Replace your blower motor and wheel using a GM unit
Replace your Dodge blower motor using a GM Blower Motor - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...-motor-301306/
Weatherpack connector repair (oil pressure):
How to repair a weatherproof connector. - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...nector-167254/
Isspro tach wiring diagram:
Questions about hooking up a Isspro tach - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...o-tach-229829/
Use any tach you want to:
Gasser tach in a diesel - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...diesel-236340/
Tach install and moving the OD button to the shifter:
Let's Screw-Up Your Steering Column With A New Tachometer and Gear Shifter! - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711032...hifter-173561/
Factory tach harness diagrams:
OEM Tach wiring diagram - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...iagram-185725/
Fix a burnt out OD indicator light:
Overdrive Indicator Light - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...-light-191515/
Replace your dash lights with LED's:
DIY: LED gauge cluster lights - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...lights-201732/
Instrument cluster refresh and LED conversion:
Repairing your instrument cluster & install LED's - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...l-leds-209884/
Halo ring (key light) bulb replacement:
key light ? - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711031...-light-210156/
Cruise switch pinout:
cruize control question - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...estion-211720/
89-91 Voltage "pulsing" issue solved!:
89-91 Voltage "pulsing" issue solved! - Dodge Diesel - Diesel Truck Resource Forums
Alternator 101:
Alternator 101 - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711012...-101-a-307266/
Old Oct 30, 2017 | 02:17 PM
maybe368's Avatar
Drivetrain
Super Duty Transmission Oil Cooler:
http://web.archive.org/web/201711012...cooler-264993/
TPS adjustment:
http://web.archive.org/web/201711032...tps-adjust.jpg
Replacing the TPS with a potentiometer:
http://web.archive.org/web/201711012...t-point-42003/
Another writeup, but with pics:
http://web.archive.org/web/201711012...ce-tps-142641/
Use a 3.0 liter V6 TPS instead of the $200 CTD TPS:
http://web.archive.org/web/201711021...ps-fix-202697/
Controlling OD using governor pressure:
http://web.archive.org/web/201711021...fix-od-156988/
TV/kickdown cable adjustment:
http://web.archive.org/web/201711021...wn_Adjustment/
Band adjustment/line pressure adjustment:
http://web.archive.org/web/201711021...e-pics-265745/
NV5600 swap info:
http://web.archive.org/web/201711021...-101507/page2/
2nd gen auto (47RH) into a 1st gen:
http://web.archive.org/web/201711021...s-93-a-114702/
http://web.archive.org/web/201711021...cs-vid-236738/
Axle vent cleanout:
http://web.archive.org/web/201711021...e-list-115036/
Getrag overfill/fluid level sight glass/temp probe install:
http://web.archive.org/web/201711021...pd-4x4-141280/
Getrag shifter operation explained:
http://web.archive.org/web/201711021...-works-148533/
Repair a broken Getrag shift lever:
http://web.archive.org/web/201711021...er-fix-250129/
Getrag rebuild info:
http://web.archive.org/web/201711021...d-data-265122/
Automatic trans build:
http://web.archive.org/web/201711021...occurs-160276/
http://web.archive.org/web/201711021...-518-a-196327/
Fix a sloppy shifter (auto):
http://web.archive.org/web/201711021...estion-171210/
Shut up that rattling 4X4 shifter:
http://web.archive.org/web/201711021...r-good-177579/
Replace front axle U-joints:
http://web.archive.org/web/201711021...joints-187074/
Getrag bearings, races and seal part numbers:
http://web.archive.org/web/201711021...umbers-260336/
Turn your non lockup 518 into a lockup on the cheap
http://web.archive.org/web/201711021...-cheap-318014/
Old Oct 30, 2017 | 02:18 PM
maybe368's Avatar
Engine
Troubleshooting and repair videos:
http://web.archive.org/web/201711021...ck-out-241246/
Valve adjustment:
B Series Valve Adjustment:
How to Adjust Your Valves - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711021...valves-143557/
KSB diagnosis (applies to intercooled only):
KSB Questions - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711032...stions-100212/
Fuel filter change:
How do I replace my fuel filter? - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711021...filter-100852/
Fuel heater now obsolete and unavailable - replace it with a 2nd gen unit instead:
1Gen preheater - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711021...heater-258221/
Where's the thermostat gasket?
t-stat lift hook - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711021...t-hook-106034/
Fan belt routing diagram
http://web.archive.org/web/201711021...ressor-105990/
Fan support hub bearing replacement:
http://web.archive.org/web/201711021...earing-247209/
Oil pressure sender replacement:
“Oil Pressure” - Dodge Diesel - Diesel Truck Resource Forums
https://www.dieseltruckresource.com/...ure%94-107789/ This url won't archive for some reason
Trouble codes
'92 and '93 Trouble codes - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711021...-codes-114381/
Fix your torn fuel shutoff solenoid plunger...
Fix your fuel cut-off solenoid - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711021...lenoid-117593/
...or install a pull cable shutoff:
Pull Cable Manual Fuel Shutoff install and keeper - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711021...keeper-211283/
Easy injector removal tool:
How to remove stubborn injectors easy ! ! ! ! - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711021...s-easy-124728/
Injector Swap:
My injector swap.... - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711021...r-swap-297436/
VE injector pump parts diagram:
Bosch VE Distributor Injection Pump - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711021...n-pump-231863/
Repairing a leaky control valve on the VE pump (with VE exploded diagram and parts list):
Injector-pump Drip Drip Drip Drip - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711021...p-drip-124850/
Repairing a leaky governor shaft and fuel screw:
How to repair a leaking Governor Shaft and Fuel Screw - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711021...-screw-239076/
Repairing a leaking fuel pin:
Repair leaking fuel pin. - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711021...el-pin-153154/
Complete injector pump reseal:
http://web.archive.org/web/201711021...inside-200901/
Installing the front crank seal the easy way:
Quickly and CORRECTLY install your front crankshaft seal - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711022...t-seal-126282/
Throttle shaft bushing part number:
Throttle shaft bushing part # - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711022...g-part-137855/
Bellcrank bushing upgrade:
Bellcrank bushing upgrade - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711022...pgrade-236074/
How does the injection pump work? (an oldie but a goodie)omplete injector pump reseal:
3000k Governor Spring - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711022...-spring-22964/
How the injection pump works - this time with diagrams:
Robert Bosch VE Pump Operation - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711030...ration-231914/
More injection pump info:
Bosch VE Pump - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711030...e-pump-227264/
Replacing the thermostat:
Replacing the Thermostat and Gasket - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711031...gasket-146039/
Injection pump replacement:
Recall #605 Diesel Fuel Injection Pump:
Videos! Pulling the IP - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...ing-ip-225480/
Head gasket replacement:
Replace Your 12v CTD Head-Gasket - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...gasket-236843/
Replace your motor mounts:
Replace Your Tired Engine Mounts - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...mounts-158316/
Get the right motor mounts:
1st Gen Motor Mount ID - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...unt-id-158399/
Vacuum pump rebuild (non-intercooled style):
What happens when your vacuum pump stops working. - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...orking-165546/
Vacuum pump rebuild (intercooled style)
Intercooled style vacuum pump rebuild - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...ebuild-268138/
'89-'91 vacuum pump(s) to '91.5+ vacuum pump:
http://web.archive.org/web/201711031...m-pump-321123/
Changing valve springs:
Upgrade Your Valve Springs - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...prings-171288/
Cam and lifter replacement:
Replace Your Camshaft, Lifters 'n Stuff . . . . - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...-stuff-255129/
Fix a broken AFC line or AFC banjo bolt:
Broke a screw but beat a powerstroke - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...stroke-173329/
Accessing that blasted idle locknut:
Fast Idle advice for a noob - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...e-noob-174233/
Easier access to idle adjustment (minor fab work required):
Easy idle adjustment. - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...stment-144126/
Extra crankcase venting:
The pressure's been building and I've got to vent . . .. - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...t-vent-199914/
Rear main seal replacement:
Rear Main Seal Install - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...nstall-202854/
Coolant change - with engine block flush by Jim Lane:
Tips on changing coolant? - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...oolant-208530/
Coolant filter install:
http://web.archive.org/web/201711031...filter-209772/
Injection pump rebuild:
VE rebuild with pics Look inside - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...inside-200901/
Pump rebuild videos:
VE Injector Pump Installation Video - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...-video-216851/
Turbo rebuild (HX-35 but our WH1C is very similar):
Holset HX35W Rebuild Thread - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...thread-226027/
Turbo R&R:
H1C to WH1C how to change with pics - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...e-pics-246279/
Torque specs:
Engine torque specs? - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...-specs-264359/
Anti theft Engine Immobilizer:
Anti Theft Engine Immobilizer you can make for less than a penny - Dodge Diesel - Diesel Truck Resource Forums:
http://web.archive.org/web/201711031...-penny-309809/
VE Pump Stand:
>>> my ve pump stand <<< - Dodge Diesel - Diesel Truck Resource Forums
http://web.archive.org/web/201711031...-stand-319351/
Old Oct 30, 2017 | 02:20 PM
maybe368's Avatar
Performance
Runaway info - READ BEFORE TWEAKING THE POWER SCREW!
https://www.dieseltruckresource.com/...d.php?t=158962
http://web.archive.org/web/201711031...i-stop-158962/
Build a Simple Tool To Stop Runaway:
http://web.archive.org/web/201711031...unaway-297596/
VE pump adjustments:
http://web.archive.org/web/201711031...r/Power_ve.htm
Some good pics of the insides of the AFC:
http://web.archive.org/web/201711031...el-mod-211443/
Fuel screw pics:
http://web.archive.org/web/201711031...onents-153598/
Fuel pin grind:
http://web.archive.org/web/201711031...el-pin-154086/
Fuel pin info:
http://web.archive.org/web/201711031...el-pin-169225/
Regaining AFC control after grinding the AFC lever:
http://web.archive.org/web/201711031...cation-217660/
3200 RPM spring install:
http://web.archive.org/web/201711031...ing/index.html
BHAF mount:
http://web.archive.org/web/201711031...icture/3521101
http://web.archive.org/web/201711031...icture/3533141
BHAF adapter:
http://web.archive.org/web/201711031...dapter-176190/
BC847's stock pot air box:
http://web.archive.org/web/201711031...air-box-63169/
Homemade intake duct:
http://web.archive.org/web/201711031...-guide-115802/
Piston pump install:
http://web.archive.org/web/201711031...install-93722/
2nd gen piston pump upgrade:
http://web.archive.org/web/201711031...t-pump-176472/
Bump the timing?
http://web.archive.org/web/201711031...advance-77230/
Timing using a dial indicator and adapter - on a VW VE but the procedure is the same for our trucks. 1.6 - 1.8 mm is a good place to start.
http://web.archive.org/web/201711040...com/injtim.htm
HTT compressor upgrade instructions:
http://web.archive.org/web/201711040...ssions-112422/
Homebuilt hybrid:
http://web.archive.org/web/201711040...hybrid-215919/
3" crossover pipe (non-intercooled engines)
http://web.archive.org/web/201711040...r-pipe-118102/
Homemade 4" downpipe:
http://web.archive.org/web/201711040...wnpipe-264047/
Longer fuel filters:
http://web.archive.org/web/201711040...-117799/page2/
Bigger fuel supply lines:
http://web.archive.org/web/201711040...pgrade-151190/
http://web.archive.org/web/201711040...sticky-174241/
Valet Switch install:
http://web.archive.org/web/201711040...100810/page16/
http://web.archive.org/web/201711040...results-57304/
PowerStroke intercooler install:
http://web.archive.org/web/201711040...cooler-149268/
2nd gen Dodge intercooler install on a non-intercooled truck:
http://web.archive.org/web/201711040...-tools-186908/
Keep your intercooler boots on:
http://web.archive.org/web/201711040...traint-240579/
Head stud install:
http://web.archive.org/web/201711040...primer-213091/
Fluidampr Install:
http://web.archive.org/web/201711040...ummins-316489/
Understanding VE pump operation:
http://web.archive.org/web/201711040...-level-172432/
Deep thoughts on the VE:
P-Pump swap:
http://web.archive.org/web/201711040...p-pics-263211/
Dynamic Timing Spacer Install:
http://web.archive.org/web/201711040...thread-318397/
woooooooooooooooooo-hoooooooooooooooOOOOOOOOOOOO.................
Old Oct 30, 2017 | 02:25 PM
maybe368's Avatar
List of dead links
I will put all dead links here...
http://store.shermanparts.com/cgi-bi...pickupchry.htm DEAD LInk
Intercooled style grille install on a non-intercooled truck:
http://www.hotrod.com/cars/project-vehicles/ Page has changed
Disk brake conversions:
http://www.off-road.com/toyota/tech/dana70discbrakes/
https://www.pavementsucks.com/tech/reardisk.php Dead links
Convert to Hydraboost:
https://www.dieseltruckresource.com/...ml#post2582890 Dead link
TPS adjustment:
http://www.pdrdiesel.com/oldsite/Tech1GTPS.htm Dead link
NP 205 transfer case rebuild:
http://www.okcnetworks.com/bronco/205/np1.htm Dead link
Dana axle rebuild info:
https://www.dieseltruckresource.com/...ml#post2774975 Dead link
KDP repair:
https://www.pavementsucks.com/forums...hp?topic=70419 Dead link
Getting those 3 sided bolts out of the VE pump:
https://www.dieseltruckresource.com/...ml#post2822314 Dead link
VE pump tweaking videos:
https://www.dieseltruckresource.com/...ml#post2596889 Dead link
3200 RPM spring install video!
https://www.dieseltruckresource.com/...ml#post2851094 Dead link
Old Oct 30, 2017 | 02:30 PM
maybe368's Avatar
Feel free to post, I have it all setup...Mark
Old Oct 30, 2017 | 04:21 PM
maybe368's Avatar
Non-Sticky threads
If you have some worthy threads that are not in the sticky, post the url's here and I will archive them. I know that Tcows has at least 1, post it here and I will include it in this thread...Mark
Old Oct 30, 2017 | 10:27 PM
maybe368's Avatar
Cool Enough for today
Well I have over half of the sticky archived and I think that is enough for today. Time to do something else for a while ...Mark
Old Nov 1, 2017 | 01:02 PM
maybe368's Avatar
Thank You
I don't remember the member that posted that Chrome plugin to recuperate the lost photos, but, Thank you Thank you Thank you. It is working beautifully and all of the Photos are being archived... Mark
Old Nov 2, 2017 | 11:09 AM
Shelby/Dakota's Avatar
5 Year Member
Thank you for taking all the time and effort to preserve these tech articles for the community.
