Anyone have crossover steering with 0-2'' lift?
Old Aug 23, 2011 | 05:15 PM
  #46
BILTIT's Avatar
Jungle, i will be installing your plates with my crossover. I will take a few pics for everyone.
Old Aug 23, 2011 | 11:36 PM
  #47
BILTIT's Avatar
Have the kingpins back together, will be starting on steering box shortly.
Attached Thumbnails Anyone have crossover steering with 0-2'' lift?-img-20110823-00232.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110823-00231.jpg
Old Aug 24, 2011 | 09:12 AM
  #48
apwatson50's Avatar
Are you going to remove your front sway bar?
Old Aug 24, 2011 | 10:46 AM
  #49
BILTIT's Avatar
Pretty sure i will have to yes.
Old Aug 24, 2011 | 11:53 AM
  #50
1990's Avatar
Originally Posted by Mieser
From what I remember the 2wd pitman arm can work, but it is a little too short. This causes the drag-link to hit the crossmember under the engine on its front lip.
When you modified the WJ pitman arm, you had to modify the taper to fit the GM TRE?
Old Aug 24, 2011 | 12:05 PM
  #51
Mieser's Avatar
Yes, I had to enlarge the taper.
I noticed the same pitman arm at PartsMike. You might be able to have him enlarge the taper if you don't want to do it yourself.
I also removed the four alignment keys in the splines. In the factory application the arm is clocked a bit. While the pitman arm will bolt up, the steering box will be in the wrong spot in its travel range once everything is aligned. I milled the keys out, but you can also use a triangle file to 'remove' them, or blend them into the surrounding splines. Just go slow and take your time.
Old Aug 24, 2011 | 10:42 PM
  #52
BILTIT's Avatar
Sway bar is off, steering arm is level with spring pack.
Attached Thumbnails Anyone have crossover steering with 0-2'' lift?-img-20110824-00234.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110824-00236.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110824-00238.jpg
Old Aug 24, 2011 | 10:53 PM
  #53
BILTIT's Avatar
Jungle, any links/pics to people who have installed the plates? Looking to see exactly how they look afterwards, particularly once they are welded.
Old Aug 25, 2011 | 09:04 AM
  #54
Mieser's Avatar
It looks like the steering arm just about touches the spring when it gets to the steering stop?
Depending on the shape of your drag link, that steering arm height should work. Its going to be tight though!
It will be interesting to see how the drag link ends up.
Old Aug 25, 2011 | 09:23 AM
  #55
BILTIT's Avatar
It doesn't hit but i never thought to see exactly how close it really is. I will double check that.
Old Aug 25, 2011 | 11:18 AM
  #56
1990's Avatar
Originally Posted by BILTIT
It doesn't t hit but i never thought to see exactly how close it really is. I will double check that.
Can you put the drag link in there and take a picture?
Just posting a direct link to you other thread.
http://www.expeditionportal.com/foru...493#post853493
Old Aug 25, 2011 | 12:08 PM
  #57
BILTIT's Avatar
Yup, i will try that tonight.
Old Aug 26, 2011 | 12:42 AM
  #58
BILTIT's Avatar
So i took some pics, you can see the steering arm is no where near touching the spring. Could adjust the stop some and gain some steering i am sure.
As for the drag link, i had it sitting too high in the first few pics and it would hit when i turned the knuckle right. I held it just above the drivers side spring and it would clear no problem through out the steering range. Just depends where the pitman arm puts the TRE once everything is mounted.
Attached Thumbnails Anyone have crossover steering with 0-2'' lift?-img-20110825-00239.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110825-00241.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110825-00242.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110825-00249.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110825-00250.jpg
Old Aug 26, 2011 | 12:44 AM
  #59
BILTIT's Avatar
More. The last pic is about where the TRE should be to clear, it could be higher.
Attached Thumbnails Anyone have crossover steering with 0-2'' lift?-img-20110825-00251.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110825-00244.jpg
Old Aug 26, 2011 | 07:53 AM
  #60
1990's Avatar
How tall is the leaf pack?
Thanks for the pics.
