any other way to remove the rear crank seal w/o the the slide hammer?
Old Apr 25, 2008 | 08:53 PM
bigragu's Avatar
Looking for advice. I am trying to change out my flexplate cheap, and thought I should change out the seal while I am there. Maybe I shouldn't remove it...it isn't leaking. What are your thoughts on R&R of the seal?
Old Apr 25, 2008 | 08:58 PM
99globalwarmer's Avatar
i think quad 4x4 has a special kit to do the rear seal. sending pm
Old Apr 26, 2008 | 09:14 AM
12valve@heart's Avatar
I pulled mine by running a few sheet metal screws into it and using a pry bar to walk it out.
Old Apr 26, 2008 | 11:41 AM
JD730's Avatar
Thats the way I've always done them.
Old Apr 26, 2008 | 12:22 PM
ofcmarc's Avatar
If it ain't broke..............
Old Apr 26, 2008 | 12:24 PM
torquefan's Avatar
I'd definitely change it while I was in there. I'd hate to do the labor all over again if it started leaking in a few weeks.
Ditto to the sheetmetal screw. It's easy to then lever it out with a pair of sidecutters.
Old Apr 26, 2008 | 12:31 PM
MoparMarv's Avatar
I drilled 2 holes 180 apart. tapped in the sheetmetal screws. Then clamped on with the vise grips and pulled it out. I little prying action works well.
Old Apr 26, 2008 | 12:57 PM
sdstriper's Avatar
If it ain't broke... Good one!
How far do you want to go now? Could remove the adapter and take the seal housing out, put the new seal in on the bench.
Old Apr 26, 2008 | 09:52 PM
rlyons's Avatar
X2, I have replaced the seal only to have to go back in and replace the adapter gasket. replace them both while you are in there, it is easier on the bench anyway.
Old Apr 27, 2008 | 01:01 AM
bigragu's Avatar
what is the part number of the adapter gasket? Does anyone know?
Sounds like some of you are experienced in the remove/replace of the A518. Can anyone give me bullet point directions of the proper sequence of removing the A518 and the NP205? 1st time for me. hate to break something. How much has to be removed(as far as tranny lines, electrical, starter) to make room for dropping the components. What about the torque converter...how do you keep the TC intact on the tranny?
Old Apr 27, 2008 | 11:49 AM
krazykarl454's Avatar
i bought a rear main seal kit that came with the seal, the gasket, and a plastic installer sleave thingy(felpro), from adavance auto for like 32 bucks seem to be workin fine
Rimcrew
Aug 19, 2012 01:04 PM
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Mar 6, 2011 01:09 AM
92smokin blacky
Feb 28, 2011 02:36 PM
RamThatStroker
Mar 10, 2003 02:21 PM
