Any body that has rebuilt there Ip with....
Old Jan 30, 2009 | 06:29 PM
Tron's Avatar
broken plunger return springs and a chunk off the rotor foot. My truck still ran with all of this broken inside the ip. I know have aluminum shavings and or shreds of aluminum in my fuel tank. Not just a little bit either. Every 2 square inches in the bottom of the tank has a shred of aluminum.
Im not worried about it making its way back to the ip. I would like to know were it came from because the truck has never run right since the rebuild.
I suspect its from the case. I was wondering if a broken spring could get caught in between the cam plate or rollers and grind away the case so know the rollers don't sit right. Or maybe the damage is somewhere else that could effect the way it runs.
Here's a pic of the broken springs and rotor foot as they called it. A new head and rotor was installed but I don't think the case was repaired and also don't know what was worn.
Thanks
Old Jan 30, 2009 | 09:12 PM
dstad's Avatar
i dont know but i would be dropping that tank and cleaning the crap out of it
Old Jan 30, 2009 | 10:12 PM
wow
wow
wow
wow
Old Jan 31, 2009 | 05:23 PM
Tron's Avatar
any body else?
Old Jan 31, 2009 | 06:20 PM
kensmachine's Avatar
Whene I worked in a fuel Inj & turbo shop it was not uncommon to see VE pumps come in with broke springs. Ken
Old Jan 31, 2009 | 07:25 PM
92roughstock's Avatar
The broken spring likely put stress on the rotor, causing the end of the rotor to break like it did. You will need a new head and rotor at the very least. May as well find another pump.
The aluminum shavings in your tank are likely from the case getting worn by the broken pieces floating around in there.
Old Feb 4, 2009 | 09:40 AM
Tron's Avatar
What parts of the case get worn that could effect the way it runs?. The pump was rebuilt already and has never run right in my mind.
rock crawler
Dec 30, 2008 10:49 PM
rock crawler
Dec 29, 2008 06:06 PM
Usta HaveA Hemi
Aug 24, 2005 01:10 AM
cumminsdriver635
Dec 20, 2004 02:56 AM
