Anti freeze Help!
Old Sep 9, 2008 | 11:10 PM
broncobilly's Avatar
Anti freeze Help!
All,
I am going to be back flushing the 93 this week, and will be replacing the antifreeze. The local Wally World carries mainly Prestone 50/50 antifreeze. I know that some argue in favor of low silica anti freeze. Can I use the Prestone 50/50, or should I look for another product with low silica anti freeze? I think Wally's also has Peak? I can't remember what else they had? I have read somewhere that cavitation isn't really a problem with the B series Cummin's?
Old Sep 9, 2008 | 11:17 PM
Tron's Avatar
I just use the standard green anti freeze and ad the diesel conditioner to it until it reads good on a fleetguard test strip.
Old Sep 9, 2008 | 11:34 PM
Philip's Avatar
Wasted effort. The test strips are only needed on wet sleeve engines. Ours isn't a wet sleeve engine. Cavition/ liner erosion isn't a problem.
Use any antifreeze you want. Just set it for the temp range of your local area in winter. Keep it changed at the proper intervials and don't worry about it.
Old Sep 9, 2008 | 11:37 PM
06RAM2500's Avatar
Peak is a better choice compared to Prestone. Get the full strength stuff and mix it 60/40 w/ distilled water. Then use a conditioner and test strips as mentioned above.
gRahAM Diesel
13
Oct 17, 2007 10:56 PM
Lyall
Sep 7, 2006 06:38 AM
screaminbanana
Jun 2, 2005 07:51 PM
clifford
Oct 8, 2003 09:28 AM
Mark Thomas
Jul 17, 2003 07:27 PM
