Another Getrag Lube Question
I was nosing around in Walmart, looking at the various oils, when I saw three types of MOBIL fully synthetic 5W-30.
Plain old 5W-30 fully synthetic.
Truck and SUV 5W-30 fully synthetic.
Extended Service 5W-30 fully synthetic, which was over two dollars more per quart than the plain old fully synthetic.
Would there be any advantage to a Getrag to use the higher priced stuff; or, is it, most likely, the same stuff in three different bottles??
I already have several quarts of the plain 5W-30 Mobil fully synthetic, when I found it marked for $2.88/quart, sitting between $6.38/quart of other weights.
Needless to say, I stocked up.
I thing that thay are a blend of syn. the most expencive is you Full Syn.
Those three are all fully PAO-based synthetics. The EP has a more robust add pack intended to support long drain intervals for the engine oil. The 5w30 T&SUV is supposed to have an add pack aimed at gasser trucks and SUVs, "not" diesel rated like the old 5w40 T&SUV. The lower priced stuff is the original formula for use in any gasser.
If I was splurging on a good syn oil for the rag, I'd go with something like RP synchromax, of a boutique flavor from SF like their MTL-P. 10w30 or ATF will work OK, but there are alot better things out there if you're going to get into that price range.
mknittle
Mar 11, 2015 10:47 AM
H8GAS
Jan 31, 2007 01:57 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
