Yet another front driveline lube ??
Old Jan 30, 2007 | 12:56 PM
H8GAS's Avatar
Just wondering for you guys with 4WD are you having to drop the Tcase crossmember to access the lube pint on the front drivelline. Maybe I have an old cheap needle adapter on my greese gun but it adds about five inches to the end which makes it real tight between the crossmember and the shaft (...hmm ). Seriously, I will if I have to, it's only needed a coulple times a year for me, but I was wondering about you guys.
Old Jan 30, 2007 | 07:59 PM
Polish Rocket's Avatar
I was just able to find the grease conical hole thanks to a post on DTR. I used the NAPA part no 715-1200. Worked great. Just position the grease hole in the down positoin. Didn't have to remove anything.
Old Jan 30, 2007 | 08:21 PM
Backwoods's Avatar
Its a bear to get at, had more success with the front wheel lifted, could then twist the tube to just the right angle.
Old Jan 31, 2007 | 01:57 PM
H8GAS's Avatar
Thanks guys...I will check out that part at NAPA too and see if it helps.
mknittle
Mar 11, 2015 10:47 AM
VICIOUS FISHER
Apr 17, 2012 09:50 AM
Racfan9
Aug 31, 2009 07:21 AM
dssimecek
Mar 10, 2008 04:58 PM
