ANOTHER cruise control question!
OK; I've read every cruise control thread and am still stumped. My cruise control worked great, but the right set of buttons were broken and hanging from the wheel. So I sprung for new buttons from the dealer, and now my cruise doesn't work at all. I checked the fuse, and the brake switch and they're A-OK. Next I pulled the clockspring, disassembled it and found it to be in perfect condition with continuity between all four sets of contacts. Cruise still doesn't work. So I hot wired the Y/R wire under the steering wheel and heard the relay click under the hood. Took it for a drive, and STILL no cruise control! ?????????
From what you say sounds like you got bad set of switches. Somewhere in here is the method to check the switches. If you can't find it I will look it up and post it. Just my two cents, Mike.
Turns out my suspicions were well-founded. Took the clock spring out, disassembled it, examined it, reassembled it, put it back in, put the steering wheel back on, and now everything works fine. Must have been a film of corrosion on the contacts where the clockspring plugs into the steering wheel connector!
worked fine for most of a 1500 mile trip. Now it's quit again.
vacuum - good
clockspring - good
ECU- good
switches - good
fuse - good
About the only thing left is the servo. How can I test the servo? I'm assuming it is not serviceable...
vacuum - good
clockspring - good
ECU- good
switches - good
fuse - good
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
dieselcrazy
Apr 7, 2003 09:36 PM
TexasDiesel
Dec 27, 2002 10:47 AM
