another 1/2 turn of fuel today
Old Jan 30, 2006 | 12:18 AM
stillsmokin's Avatar
Well I was going to wait till spring but, the weather was good today and the full power screw went in another 1/2 turn. Dropped idle to 850 while I was at it. EGT's are about 800 post turbo on decent acceleration and 30 PSI has happened! The H1C turbo seems to stuggle past 20 psi but boost is coming on much faster than at the previous setting. I ended up adjusting the aneroid back to the stock setting and setting the star wheel at almost the top of the threads to control smoke, somewhat.
I haven't cleaned the weld scars off of the screw yet but there isn't much more to go before the nut binds on the weld scars. How much further can I go before its pull cable time? Still running on the stock solenoid and need to till march or so then it's go time for sled season. I can shut down easy now so I am probably ok. I would like to keep the solenoid if someone knows a way to keep the plunger on? Perhaps a custom nylon plunger would fix the problem.
Old Jan 30, 2006 | 12:24 AM
Underpsi's Avatar
The reason you stop turning in the fuel screw isn't to prevent breaking the shut down solenoid its to prevent runaway.
Old Jan 30, 2006 | 04:43 PM
https://www.dieseltruckresource.com/...27&postcount=5
This worked for me. I put it in in August and it's still shutting the truck off.
Old Jan 30, 2006 | 09:26 PM
I already know plenty about runaway . For the record it would be nice if the solenoid works when I go fuel crazy, I think the pull cable should be more of a safety feature on a heavily modded truck.
THANKS WANNADIESEL FOR THE TECH TIP
Old Jan 30, 2006 | 09:46 PM
Underpsi's Avatar
Haven't had a single problem with my solenoid (knock on wood)
Old Jan 31, 2006 | 04:09 PM
About 2 weeks after I said that mine got munched. I bet you have 2 weeks.
Old Feb 1, 2006 | 12:04 AM
Underpsi's Avatar
oh oh.....
stealman1
Nov 9, 2007 11:07 AM
expressfish
18
Mar 11, 2007 04:28 PM
TurboCrisco
Jan 10, 2007 03:30 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
