Ammeter Gauge
Ammeter Gauge
This may sound pretty stupid but I just noticed that my ammeter gauge doesn't work. It just stays in the middle the whole time but im pretty sure its suppose to move. Have any ideas of where i can check to diagnose the problem?
Thanks Kevin
Thanks Kevin
Our trucks have Voltmeters, not Ammeters. Although it's common to get the 2 confused. An Ammeter shows rate of charge...how many Amps are flowing one directing (charging) or the other (discharging). Ammeters do fluctuate quite a bit depending on what the battery needs at the time. For instance, we could see up to 120 Amps of charge for a short time on ours. A volt meter just shows what voltage the system is currently opperating at. Most vehicle systems shoot for something like 14-14.6 volts. And try and keep it there. That's why our guages don't really move around. They do dip down quite a bit when the grids kick on. But you already knew that since your lights get so dim when that happens that you have to stick a Mag-Lite out the side window to help
My truck does have an Ammeter not an Voltmeter it shows charging or not charging and it NEVER moves its always in the middle so im pretty confident that it doesn't work. This is a Canadian truck for the record so maybe its just the American trucks that have the voltmeters then
Up to 89 they have ammeters. 90+ have a voltmeter. Most of the 90+ work. Most of the 81-89 don't
. My 89 is Canadian too with speedo head and other parts swapped around so I know how fast I'm going lol.
mtl0727
Oct 12, 2005 01:02 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
