Altinater mods worked, new ?
Old Feb 18, 2008 | 08:46 PM
sshewins's Avatar
Hi guys, thanks for helping me fix the problem with dad's alt not charging. I did the mod in which you take brain box (PCM?? - behind batt) out of the loop and let the alt decide when to charge. My new question is the check engine light flashes on/off, sometimes it stays off, sometimes on. What could be causing this and/or is it normal?
Other than that, we're both very happy with the way it performs. (I get to test drive it from time to time)
Again thanks,
Old Feb 18, 2008 | 11:01 PM
flashgordon's Avatar
You my still end up with a brain box.............Check and clean all you connection before you go out and buy one.
Flash.
Old Feb 19, 2008 | 03:57 PM
sshewins's Avatar
It's still there, it just don't controll the alt charging function anymore. When plowing, as soon as you let off the joystick, the needle on gauge pops right back up...everytime. The mod was found in the sticky column.
Old Feb 19, 2008 | 05:31 PM
Check the trouble codes, that will tell you why the PCM is unhappy.
dan1stgen
Dec 16, 2010 10:28 AM
1stGenBikeHauler
Jul 16, 2003 04:51 PM
feets
Mar 10, 2003 12:22 AM
03quadduallyho
Feb 2, 2003 07:06 PM
kingofdodge7131
Jan 25, 2003 12:05 PM
