Are all 12 valves equal in the front end?
Old Dec 31, 2012 | 01:26 PM
thechoochlyman's Avatar
Minus timing cover, of course.
The reason I ask is because I am installing a vacuum pump and power steering assembly from a P-pumped engine. I am just wondering if there is any reason why it wouldn't work. The gear on the pump appears to be the exact same, minus the little nipple on the end, and my timing cover has a spot for it to go into. And I also got the oil line plumbed in, as well.
Old assembly
New Assembly
Old Dec 31, 2012 | 01:57 PM
simplysmn's Avatar
Awwwww you have a double diafram pump on it ?89-90 ?the later style pump's all inner change 91.5 n up
Old Dec 31, 2012 | 02:02 PM
You think they changed the gears or something after the first year or so of using the Double Diaphragm?
I did mange to get it on the engine, but I haven't started it yet.
I had to put the oil pressure sender elsewhere and cut off the bottom half of the throttle bracket, but it fits. I'm probably just being too overly cautious, but I just want to know if there is a reason why this will grenade my engine or something.
Old Dec 31, 2012 | 02:52 PM
jimbo486's Avatar
You won't have any issues. There's a port in the block just behind the power steering pump that the oil pressure switch can use.
Old Dec 31, 2012 | 03:33 PM
simplysmn's Avatar
http://www.fixinrams.com/ Call this guy he's the master on the pump's
Old Dec 31, 2012 | 03:43 PM
Thanks
I was going to use that port, but couldn't access it very easily. That assembly is really really long.
This is what I ended up doing. I added about two feet of wire onto the sensor.
Old Dec 31, 2012 | 03:48 PM
cmann250's Avatar
I have one from a '94 on my pick-up. It hasn't blown up yet and I swapped it on probably 10k miles ago in the summer. An intercooled throttle bracket with some whittling and rewelding makes it look a lot less hill jack.
Everything will fit in there like it's supposed to. You just gotta be crafty
Old Dec 31, 2012 | 03:54 PM
I really like that term, "hilljack."
For now, my throttle bracket is being held by one bolt up top.
Maybe I'll luck out and find an IC bracket sometime.
BTdubbs, I'm doing this for a hydroboost conversion.
Old Dec 31, 2012 | 09:22 PM
jimbo486's Avatar
What hydroboost are you planning to use?
Old Dec 31, 2012 | 11:58 PM
2nd gen 24 valve setup. I already have everything in place - just have to attach one more hose in the morning and I'll be ready to test it out.
Old Jan 1, 2013 | 12:04 AM
jimbo486's Avatar
Right on! Eager to hear your results. It'd be cool if you create a thread covering the swap including all the necessary parts and tasks involved. I've heard good things from others swapping hydroboosts from Chevy's, IIRC. Any particular year or would any setup from '98.5 to '02 work?
Old Jan 1, 2013 | 12:14 AM
I'll try to do a writeup here once I get everything finished up. For now, I'll post up some pics and basic info for ya.
I put on a red head steering box during this swap - my old one was really loose. I can already tell this thing is tight as a drum.
I used a 12 valve vacuum pump (the 24v gear on the back is completely different), and mated it to a 24v PS pump (for the dual returns on the back).
As mentioned, I had to relocate the oil pressure sender, attach the oil supply line, and also cut off the bottom half of my throttle bracket to get everything to fit.
In order to get the booster in place, I just had to drill two new holes to the right of the push rod, and enlarge the hole in the rod to 1/2 inch in order to fit on my pedal. It does sit a bit high, however. You can also see the red fuel line I used for the return.
I had to adapt my lines to 12 and 14 mm. They were 1/2" and 9/16" before. I was able to adapt the smaller size down, but I had to cut off the larger one and splice in a smaller end.
If you have all of the hoses from the parts truck, you should be able to just bolt everything in with little other modification other than the brake lines, and maybe putting a tee in the PS return lines if your pump only has one return port.
Old Jan 1, 2013 | 02:19 AM
comotionman's Avatar
is that teflon tape or some kind of pipe dope i see on the fitting(s) going into the master cylinder?
Old Jan 1, 2013 | 02:52 AM
jimbo486's Avatar
Ahh, that's probably why the oil pressure switch wouldn't work in the original location.
Old Jan 1, 2013 | 06:18 AM
KRB's Avatar
KRB
Whats all the plumbing there by the IP where the AFC fitting is supposed to be?
Curious to see how much improved braking you have.
