afc lever
afc lever
i am planning on taking my afc lever out. If so can i put it back in if i dont like results? All i need to do is just tap the little pin out with punch and it will fall out right?
thanks
thanks
Yes, you can remove the lever completely if you want. If you don't like it put it back in. But if you grind the foot off and don't like it of course you'll need a new afc lever. I was conservative and only ground about 1/3 to 1/2 off mine and it's fine.
Tap the ***** out and then you can just "tap" the holes with a 1/4-20 and reinstert set screws with blue locktite. Then there is no "gooping the ***** back in" just back out the allen set screws and replace the lever and reinsert the screws. Works slick.
GLHS
Jan 20, 2007 10:55 AM
