1/2 AFC lever grind
Old Jan 10, 2006 | 10:40 PM
devildog5001's Avatar
1/2 AFC lever grind
Is it possible to grind off half of the lever (still a boot shape minus the toes) for some power without all of the low end smoke. If a guy took .100" off once of twice would it be worth the effort/risk that you would pass an emissions test? Just 12 more years and in Colorado I'll be eligible for a 'collector's plate and one final emissions test, if the law remains the same. In 12 more years that lever might be worn off!
Old Jan 11, 2006 | 12:19 AM
Bushy's Avatar
Patron Saint of 1st gens
The more you take off the more smoke you'll have...having said that I have (currently) just a bare hint of the 'foot' remaining and I passed our emissions up here...I did have to back the timing right down and pull the FF screw out a couple turns but I passed with no problems...surprised the heck outta me actually...
p-b...
Old Jan 11, 2006 | 07:28 AM
gman07's Avatar
Here's what mine looks like with the lever 1/2 gone and the FF screw in a couple turns. The starwheel is in the stock position and the smoke screw is out as far as possible.
Old Jan 11, 2006 | 08:47 AM
Alec's Avatar
I apologize that I have not had time to do any actual testing of this, but, FWIW, looking at how the pump works, the shape of the AFC grind is quite important to its operation. That foot has a curvature that I believe is intended to minimize any effects from the geometry of the lever it is attached too -- that is, in the original design, all of the relationship between boost and fueling is supposed to be defined by the AFC eccentric.
If you change the shape of that foot, I believe it is possible to make it almost stock at no AFC travel (no boost), and much more fuel at full AFC travel. Something more like this:
I also think that you can get maximum fuel a fair bit before the foot is ground off flush, so a "half grind" might really be closer to a "7/8" grind, if that makes sense.
Once again, I apologize that this is all from reading up on the VE and looking at my pump core -- no testing as of yet.
Old Jan 11, 2006 | 11:32 AM
Underpsi's Avatar
if i knew that the afc lever rode on I might understand but I really have no clue. If what you say is true then we would still be able to pass the etest with the afc grind
Old Jan 11, 2006 | 03:19 PM
Alec's Avatar
The AFC lever (#3) is the maximum travel stop for what Bosch calls the "Tensioning Lever" (#12).
#12 is what moves the slip collar that covers the spill port that controls how much fuel is pumped per stroke.
Old Jan 11, 2006 | 03:23 PM
bgilbert's Avatar
Well said Alec. FWIW, I made 337hp with a 1/2 ground afc lever, 35-16, pod's..
Old Jan 11, 2006 | 07:14 PM
Underpsi's Avatar
thanks for the info, the picture is a little unclear of which way the levers move and that though.
Old Jan 11, 2006 | 07:50 PM
G1625S's Avatar
yeah, you've gotta live with those diagrams for a little while till they start to sink in
Old Jan 12, 2006 | 02:16 PM
Great details, cool pump diagram too. Thanks for all the info guys.
GLHS
Sep 24, 2006 11:22 PM
puffmagicdiesel
Mar 26, 2006 09:35 AM
BIGTAN408
Mar 16, 2006 05:15 PM
Underpsi
Oct 24, 2005 04:16 PM
G1625S
Jul 4, 2005 01:32 AM
