Adheisive sp?? Remover
Old Jun 16, 2005 | 08:51 PM
fearthedeere's Avatar
Ok ive started to remove the plastic moldin along the side of the truck. whats a good remover to get all the sticky off. also what the heck do they put on the backs of Banks Power badges for the life of me i cant get the blasted things off.
Old Jun 16, 2005 | 08:58 PM
oscaroc's Avatar
I used a rubber disc that fit into a drill. I think 3M makes it . Works really fast and it wont burn your paint.
Old Jun 16, 2005 | 09:02 PM
DODGE 92's Avatar
ia used a rubber disk too
Old Jun 16, 2005 | 09:06 PM
I dont really care bout the paint its ****ed under the molding anyway good thing i started to take it off now or the bottom half of my bed would have been on the ground in a few years. there was water and dirt and the paint was all nasty and chipping off and there was some surface rust begining. im tryin to decide if im gonna line the rockers up to the bottom of the molding or the top. anyways its less to paint.
Old Jun 16, 2005 | 09:18 PM
chasd60's Avatar
I heard Goo-B-Gone will remove the adhesive but I am not sure. I do know that you can by an adhesive remover in a spray can at any auto paint supply store.
Old Jun 16, 2005 | 10:18 PM
ihpower's Avatar
wd40 usually works for me but you will have to clean it really well before paint
Old Jun 16, 2005 | 11:14 PM
jiMMyCTD's Avatar
3m also makes a sweet adhesive remover as well. jiMMy
Old Jun 16, 2005 | 11:58 PM
dezlsmkr's Avatar
Rubber disk all the way!!! I used it before i repainted my truck to remove everything. I beleive it is actually a Pinstripe remover but it works for all the adhesive great.
Old Jun 17, 2005 | 10:23 AM
spunbearing's Avatar
the 3m disk is the only way to go!
Old Jun 17, 2005 | 08:53 PM
rebal's Avatar
I second ...or third ? 4th ... ok ok the rubber disk its wonderful
Old Jun 17, 2005 | 09:30 PM
DODGE 92's Avatar
another way since you got rust use a fine brissel wire brush that hooks up on a grinder that will remove everything paint,rust,bring it back to metal paint it put your rockers under that molding and put molding back on great way to hide mistakes to put molding back on if you want a cheap trick by some clear silicone for outside windows cost 2$ a tube and seels everithing good so no more dirt gets under there thats wat i used all aroundon my truck first i used that 3m black molding holder crap takes forever to dry and who wants to spend all day holding molding in place with silicone put it on molding let it dry for about 30 min then put it on it will stay were you put it not slide down like that 3m crap that costs 15$ for a small tube put molding back before u paint seel them all around with that silicone and paint over them see that silicone is paintable so its gona be sealed without showing a mess looks like a pro did it
Old Jun 18, 2005 | 08:46 AM
Im not putting the molding back on i think im goin for the slim look. Eventually i wat to debadge everything and run a 2-3in strip around the whole truck and paint the model and Dodge on it. I think thatd look sharp
Old Jun 18, 2005 | 10:59 AM
92DIESEL's Avatar
FEarTheDeerE, before you take everything off, look at my truck (pics in gallery). I have the true 'stripper' from the factory.
Old Jun 18, 2005 | 11:48 AM
Ive all ready took the stuff off. I like the stripped look. i have a question tho i cant post the pic on there but lookin my gallery and look at the rockerliner pic. is this too high or should i do the other one.
Old Jun 18, 2005 | 12:54 PM
K the pics are there note that my paint art work stinks but you should get the idea
Tommy93w350
Aug 11, 2007 09:17 PM
WEATHERBY460
Sep 2, 2006 06:16 AM
fearthedeere
Feb 9, 2006 06:38 PM
CrashCade
Jul 5, 2005 01:32 AM
ten8fiftyone
Aug 11, 2004 10:34 AM
