Adding Cigarette Lighters?
Old Jun 18, 2005 | 02:55 PM
Begle1's Avatar
Well, in today's world I've decided that it would be really useful to add a few cigarette lighter sockets to my truck, so I wouldn't have to keep swapping around power cables from my pull-out ash tray all the time. I'm thinking to go out to the junk yard, pull off 3 sockets with the wiring and such attached, attach all three to a bezel of some kind, mount the bezel under the glove compartment and then wire in all the sockets.
Is this possible? Where could you draw the power off of?
What kind of cars had cigarette lighter sockets that popped out really easy?
Old Jun 18, 2005 | 03:51 PM
A-Poc's Avatar
If you're doing it under the glove compartment just splice them to the factory cigarette lighter that's already in your truck. I use the power wire off that ash tray for a few things already It's fairly close and easy to get to.
Old Jun 18, 2005 | 04:14 PM
ares's Avatar
i put two in the ash tray, then i ran a line in from my aux battery to power the lighter sockets and the radio. comforting to think if i leave stuff on ill still be able to start in the moring.
Old Jun 18, 2005 | 10:54 PM
fschiola's Avatar
Radio Shack sells a power outlet kit with a mounting bracket and fuse holder and all of the wiring for about $7.00. They don't look bad installed under the dash lip.
Old Jun 19, 2005 | 02:10 AM
Den's Avatar
Den
Harbour Freight sells a 4 outlet deal with a lighter plug on the end. I removed the plug and wired it into the truck with a fuse. It fits perfectly under the heater vent and doesn't slide around.
Here's a link to a 3 outlet version
Den
Old Jun 19, 2005 | 06:09 AM
RV dealers and camping stores sell outlets that are made to be flush mounted in cabinets. With a little shiming and some strong adhesive they would look like they grew anywhere you cared to put them. If you're going to plug a lot of crap in, run a seperate wire off the battery with a fuse or a self resetting circuit breaker.
Totallyrad
Mar 18, 2017 10:16 AM
CTD01
May 22, 2006 09:13 PM
boarbuster
Feb 21, 2006 11:09 PM
HL649
May 31, 2005 11:14 PM
2500CTD
Mar 29, 2005 02:21 PM
