AC evaporator drainage port?
Where is it? Inside the cab or in the engine location on the passenger side? I have water damping the passenger side on my 2001 Ram 2500 5.7 diesel. I've read here the same problem and the recommended fixes but I can't find exactly where this drainage port is located
I can only speak for the early trucks but the drain for the heater box is outside. Passenger side, firewall just below the blower motor. I don't think there would be much of a difference between them and the 2nd gen trucks so it could likely be in or near the same location on your 2001.
Found it
A little perseverance and a step stool and there it was sticking out of the firewall below canister, a part of the AC system. It wasn't plugged as I hoped it would be, but I went a head and install a short plastic tube that fits snugly in the port. No resources here in Panama if it's leaking water from inside from some AC component and AC is a must 😟
Odds are good you got leaves plugging it from the inside. If so, you have 2 choices.
1. Take half the truck apart to get the heater box out, open and clean it.
2. go get a 4" marine scupper, install it on the air box under the dash, and screw off the cap to reach in and clean it at will. If you get one with a clear cap you can inspect it without even doing that.
Would this work?
Ebay ads are not allowed on DTR
But that would probably work,but round is better IMO...Mark
CRSmith
Apr 9, 2007 04:58 PM
QWKRTNU
Sep 26, 2006 10:22 PM
...Mark
