AC Drier Leaking???
Old Jun 23, 2025 | 09:03 PM
Thespruce's Avatar
AC Drier Leaking???
Over the last few days after work I have been trying to convert my 1993 crew cab conversion to R134a refrigerant. AC systems are like Greek to me, but only one way to learn I guess. I swapped out my drier, and flushed out the hoses, compressor and condensor. Put in all new gaskets and O-rings.
When I tightned the hoses onto the drier it seemed like the mating surfaces weren't parallel - the hose/orifice/thick part of the gasket is on one side, but the nut you use to tighten the flanges together is off to the other side. The gasket appears to be the same kind as the one which came out originally. When I tried to pull a vacuum on the system there was a large leak. After double checking everything, I clamped the hoses flanges/mating surfaces on the drier on the side opposite of the studs, and waddya know, it holds a good vacuum now. Am I doing something wrong? Here is a pic showing the drier, from above, with the vice grips on helping to hold the side away from the nuts/studs. Any advice?
Old Jun 27, 2025 | 08:39 PM
jerseybud's Avatar
those are a bear. Nylog was recommended to me when I had the same problem . It worked and helped me discover the leak at the hoses
That and aftermarket stuff is junk
Last edited by jerseybud; Jun 27, 2025 at 08:40 PM. Reason: forgot that aftermarket parts are total junk
AZ2A
Nov 19, 2021 03:06 PM
samiam4
Sep 10, 2020 08:03 AM
nedz19
May 14, 2011 09:00 PM
jpajax
Jul 13, 2008 10:03 PM
Ramdriver15
Jul 30, 2006 09:07 AM
