AC chirp
Old Aug 4, 2012 | 07:48 PM
Exekiel69's Avatar
AC chirp
The one on My 93 ford is doing it more often now and I'm worried it could seize. I read here before some one replaced the bearing on one before but can't find the thread, the problem is the AC on mine works wonderful and it would be a shame to do it all over if there is a way to lube the bearing or replace it completely.
Any ideas? Thanks.
Old Aug 4, 2012 | 09:18 PM
93flatbed's Avatar
Possible it's just a belt chirp? Maybe spray a little water on the belt while it's doing it and see if it changes. Just a thought since our tensioners ain't the best ever produced.
Old Aug 5, 2012 | 05:37 AM
Mike337's Avatar
Another belt fix: Shut off engine, put some Comet/Ajax powdered cleaner on the belt, not a ton, a little goes a long way, restart.
Make sure no ones face is near the engine when you restart it.
Old Aug 5, 2012 | 08:13 AM
Exekiel69's Avatar
It sounds metallic to Me like a bearing but I would love it to be just the belt, I'll try is this monday when I see the truck.
Btw is there a way to replace that bearing with a new one with out disconnecting the lines from the pump?
Thanks.
Old Aug 5, 2012 | 11:05 AM
93flatbed's Avatar
To do it in frame would probably be a pain with the puller to get the clutch off. But being yours is in a ford you may have more room? I think it would come down to how much room you have and how compact your clutch puller is.
Old Aug 5, 2012 | 11:19 AM
Exekiel69's Avatar
I think I can do it with the pump still mounted, would any puller do? I remember there was a thread about this but can't find it in the sticky anymore.
Old Aug 5, 2012 | 03:09 PM
Exekiel69's Avatar
I found the thread here https://www.dieseltruckresource.com/...ressor+bearing Jim Lane and Sdstriper gave Me the links directly to the site where I can get the bearings, I just forgot where it was.
Thanks for everything, I give it a try and post some results this time.
Old Aug 7, 2012 | 08:58 AM
Exekiel69's Avatar
Anyone know what type of puller I need to get the clutch/bearing out?
I ordered the bearing but I haven't looked at the pump yet.
Thanks.
Old Aug 7, 2012 | 10:52 AM
rrgrassi's Avatar
You can "borrow" the needed pullers from O'Reilly.
Google can be your friend on this one, as long as you know which compressor you have.
Old Aug 7, 2012 | 06:45 PM
Exekiel69's Avatar
Yea I have no idea which one it is, I know it is the factory one I toke from the 89 CTD.
No O'Reilly stores around here, if anyone know what type of puller I need please share, I have several but I'd like to have the right one when I get to the truck.
Thanks.
Old Aug 7, 2012 | 07:54 PM
rrgrassi's Avatar
See if they have a "loan a tool" program. Basically you pay for the tool, then when you return the tool, you get your money back.
For the R4 compressor on my MB I had to go to Auto Zone for one puller, and O'Reilly for the other one.
Old Aug 10, 2012 | 07:38 AM
Exekiel69's Avatar
I found this on line, does it look like the ones on a 89 at all?
At least it gives Me an idea of what I'll be working on.
sluggo42
15
Nov 14, 2010 11:18 PM
bigbaddiesel
Nov 4, 2003 03:33 PM
Commatoze
Mar 18, 2003 11:44 AM
TPilaske
Dec 5, 2002 08:02 PM
sixtogo
Nov 21, 2002 10:23 PM
