ac pump parts
Pick one, in less than two minutes I see three national chain hardware stores that have almost everything you would care to replace on one, if you can. Might want to look into the tools it takes to do an a/c clutch. OR $400 bucks for a new one with clutch...
Check with Auto Zone, they have them listed but not sure if they really have them.
Does it have a C-171 compressor?
AC Clutch.
http://www.autozone.com/autozone/cat...entId=cat30062
Bearing.
Jim
AC Clutch.
Bearing.
Jim
Thank You. A member here did His with the pump still connected, I just finished doing mine (cools great btw) and all I want is to get rid of the chirp noise this is why I want to do it with the pump still connected and I had to customize this pump to work on My ford along with the cummins so I rather not buy a new one if I can help it.
O'Reilley has the most pieces parts I have seen available for the C171
http://www.oreillyauto.com/EW3/Displ...1&newPage=true
Checkmate
Mar 2, 2008 05:55 PM
BRUISER
May 2, 2007 09:20 AM
CTD_Neil
Jul 19, 2005 08:13 PM
xj2extreme
Feb 20, 2003 10:38 PM
