A518 upgrade or 47rh swap?
I found a local 2wd 47rh from a 94 with known high miles but unknown working order for $500.
Assuming I could use the 4wd tail housing from my 518 on the 2wd 47rh.(can I?) What do you guys recommend?
1. Converter and valve body upgrade on the 518?
2. Build the 47rh and swap it in?
I will be plowing snow and on occassion, towing 7-10k.
More then anything it will be a DD.
TIA
TIA
$500 is too much for a core IMO. Output shaft on the 2wd is longer than a 4x4 output shaft. the 47rh swap can get expensive and your 518 should have no problem towing 7-10k. build the 518 the right way and you should have no problems.
aluminum planets + modded truck =
. If you're going to source from a 47rh just use the entire thing and do the conversion, but from what it sounds like you want to do you shouldnt have to go that heavy duty.
I vote for upgrading the A518. Why? Because it is plug and play, it goes right in. and then it works like stock.
Many times I have contemplated a 47RH and then I read threads about guys having to manually control OD and LU. Kind of defeats the purpose of having an automatic if you ask me. Then you have to modify the truck and the mounts and driveline to get it to fit. Too much trouble.
You might be more handy with the wrench though, as I am not.
Very good point head!
I just can't believe how easily theCTD pushes through the stock converter. And I figured the lockup feature of the 47rh would help with that. I hope I'm not expecting to much from a converter upgrade as I could be dissappointed afterwards.
i wouldn't mix and meddle with combining parts from the 46rh and 47rh. A 518 built the right way by a reputable transmission shop should work just fine for your needs as long as you tell them your goals.
Firstgenfanatic
Jul 9, 2011 03:17 PM
1-5-3-6-2-4
Jul 18, 2010 12:51 PM
Firstgenfanatic
Jul 21, 2009 09:52 PM
1stgen1993
Dec 14, 2008 08:19 PM
BC847
Jul 29, 2007 05:08 PM
