A518 transmission problem
Old 12-22-2014, 10:14 PM
91dodgecummns's Avatar
I have a 91.5 dodge d250 has auto 4 speed trans 518 problem is it shifts from 1st to second normally but 2nd to 3rd bout 10mph so bout 10 to 15mph it will be in 3rd gear already never stays in 2nd but if I manually shift it will stay in 2nd
Does anyone know what would cause this
I've already tried the tv cable and didn't fix
It's only really a problem when I'm pulling a trailer cause it'll be in 3rd bout 15mph and I'll have to manually shift every time.
Old 12-23-2014, 11:49 AM
Guess no body knows
Old 12-23-2014, 12:57 PM
cougar's Avatar
Check the TV lever on the transmission to see if it hasn't come loose. The lever may be moving, but the shaft it clamps to may not be.
Old 12-23-2014, 02:20 PM
Checked it and it's all connected and working. Think it could be internal prob?
Old 12-23-2014, 02:31 PM
patdaly's Avatar
Give Angry Johhny time to read your issue, he will know.
Old 12-23-2014, 02:32 PM
Ok thanks
Old 12-23-2014, 03:49 PM
Received 1,637 Likes on 1,112 Posts
Did you adjust it as it the FSM ? the kickdown requires it's spacing relative to the throttle lever to be specific, as if it's too far away from the throttle lever pin, it won't hold the trans in any gear.
take a picture of the tv lever where it meets the throttle pin that runs through it. Make sure you have the proper tension spring on there as well.
AJ is the dude, though. Amazing knowledge of transmissions that guy has...
Old 12-23-2014, 04:25 PM
j_martin's Avatar
I don't believe the TV (Throttle Value) cable/lever does anything with shift point, only shift hardness. The shift points 1-2 and 2-3 are modified by the governor in the tail section.
Usually it's debris that hangs the governor, so it's probably time to pull the pan and take a look. 'tis not a good sign.
Old 12-23-2014, 06:26 PM
Ok so pull the pan and what do I look for ?
Old 12-23-2014, 07:40 PM
diesel402004's Avatar
I found the tv adjust to allow lots of adjustment on the "shift point" prior to tranny rebuild. Now, not at all. The 2-3 shift is normal except I used to like it to get a little more revs at max throttle with large load, and now I have to manual if I want that. Supposedly there is a "green" spring I could install in the body to change the 2-3 shift, but it's not worth tearing it all apart again to me.
Old 12-23-2014, 07:43 PM
Ya Idk this problem has me stumped. It shifts though all the gears but only stays in second gear for literally 1 second and then shifts in to 3 at 10 to 15 mph even if I Floor it it'll stay in 3rd
Old 12-24-2014, 07:47 AM
Mcmopar's Avatar
Governor or an internal VB issue. Probably both
Old 12-24-2014, 09:02 AM
j_martin's Avatar
If the fluid is old, it might be breaking down and depositing varnish on moving valve parts and such. That used to be a problem with Dexron. Don't know if it still is with the modern synthetic fluids, like ATF+(n).
Just for grins and giggles, throw a helping of one of the solvent trans fixer products in and run it a little before you pull the pan. Even if it seems to fix it, pull the pan and do a fluid and filter change anyway.
Old 12-24-2014, 09:36 AM
Angry Johnny's Avatar
The throttle valve and the cable adjustment will indeed affect the shift point if opened far enough to override the governor. That is the only way the trans knows (for 1/2, & 2/3 shifts) how far the throttle is opened.
Were any mods done to the valvebody or is this something that just developed? Any work done to the truck prior to this happening?
Make absolutely sure the throttle valve lever is connected to the cable at the trans, they tend to wear and pop loose. Also adjust the cable so that it pushes the lever all the way back at WOT, maybe even lengthen the cable a smidge more. Have a helper work the pedal from the inside as you may not be getting full throttle from the pedal.
Old 12-24-2014, 10:14 AM
aicomp's Avatar
Great info. Thanks Angry Johnny
Firstgenfanatic
03-10-2008 07:50 AM
Firstgenfanatic
02-11-2008 09:49 AM
goodtyms
09-06-2006 09:03 AM
goodtyms
09-01-2006 06:33 AM
2002cumTRBODSL
11-25-2005 10:23 PM
Quick Reply: A518 transmission problem
