93 GETRAG Trans problems?
Old Mar 28, 2006 | 06:51 PM
yebatza's Avatar
I have a '93 4wd manual trans w/ 400k miles, trans. rebuilt @ 300k. On my way to work the shifter handle started rattling (abruptly) accompanied by a distinct vibration felt in the shift handle (If you have ever had an aluminum clipboard in contact with the transfer case shifter you know the kind of noise). The rattle/vibration occurs under a load in fifth gear only. Checked / changed the oil in the trans and it dampened it a tad. No obvious metal in oil. Based on previous experiences, problems with the Getrag always appear in fifth gear - I am hoping that this time it is sumtin different
Old Mar 28, 2006 | 06:55 PM
G1625S's Avatar
Well, 5th gear is right near the output bearing...how was the oil level when you drained it? Have you been running the factory fill (3.5 qts) or have you been overfilling by a QT? 100k is a long way to go if the bearing preload was set too loose, but maybe it was a bit tight?
EDIT: Welcome to DTR! We'll get ya squared away...though you may spend all yer money in the process
Old Mar 28, 2006 | 07:31 PM
yebatza's Avatar
Oil, upon draining was down about a quart as a recent leak developed near the back of trans. I used synthetic oil and always overfilled - but it appears the recent leak is substantial. Also - I did not rebuild trans and can't infer if preload was done properly.
Old Mar 28, 2006 | 08:09 PM
G1625S's Avatar
The other thing that comes to mind is the 5th gear torrington (not sure on the terminology...or the spelling) bearing. Unlike the others, the 5th gear is a 2-piece affair, like crank bearings. In my tranny, that was the only bearing that looked tired. Maybe you lost that and the gear is rattling on the mainshaft. If you've got a pretty good leak, chances are the output bearing and whatnot are getting starved. You'll at least be looking at pulling the tranny for an inspection, to be safe.
Old Mar 28, 2006 | 09:17 PM
yebatza's Avatar
I agree - that appears inescapable.
Old Apr 15, 2006 | 08:48 PM
yebatza's Avatar
Pulled the tranny and found one tooth missing. Input shaft bearing is loose - big time!
Old Apr 16, 2006 | 06:17 AM
G1625S's Avatar
Tooth missing on the input shaft? How are the other gears? When I built mine, I had to get an input shaft, bearings, seals and a small parts kit. I think I got out of it for less that 500 bucks doing all the labor myself. Keep us posted.
Old Apr 16, 2006 | 07:55 PM
yebatza's Avatar
sorry for being vague - one tooth was broken off on fifth gear (last gear/ nearest output shaft). Other gears / synchros look fine. The input shaft is sloppy as hell. What really blew my mind was the bronze bushing in the flywheel- this thing was mushroomed and cracked. If I would have tried to use a puller it would have disintergrated.I Will have to post a photo. What is even more bizarre is the mechanic who did the last rebuild told me he used the kevlar bearing supplied with the SB clutch. After seeing this I am going to use a ball bearing pilot.
Old Apr 16, 2006 | 08:16 PM
mhuppertz's Avatar
Pilot bushings and bearings don't tend to go out unless there is a reason, like a gear chip momentarily locking the trans and mushrooming the pilot bushing! Hope it comes out OK. There is a post... here:
PapeCAT vbmenu_register("postmenu_938628", true);
Member's Photo Gallery
Member's Classified Ads
From the Horses Mouth
Here is the excerpt from Terry aka Mysteryman that I cited, and the link to the forum for tdr members:
http://www.tdr1.com/forums/showthre...80&page=1&pp=15
mysteryman wrote:
The bearing that fails is the rear main shaft bearing.....This happens due to some of the things I mentioned earlier in this thread....
What you have is a Timkin tapered roller bearing pressed onto the main shaft.....the race is then placed into the rear of the case partially sticking out. Then the tail shaft housing goes over the part of the race that sticks out pressing it down onto the cone....There are shims that go between the race and the tail shaft housing that adjust the bearing clearance..
The failure comes when the clearance is too tight (TOO MANY SHIMS)
This loads the bearing too tight.....When the trans heats up things expand...
This causes the race in the case to lock on the cone and rotate in the case...
This wears out the case and causes the trans to get real hot real fast...Then often times the case will crack between the main shaft and the countershaft bearing bores..... Party over !!!
The bearings in the Getrag are Timken tapered roller bearings just like the front wheel bearings. On front wheel bearings you adjust the clearance with the spindle nut....On a Getrag you stack thin shims.....For new bearings you want a +.006 preload . For used bearings you want .000 clearance.....
Back in the early 90's we were having problems with the remans getrag was sending us...I had about 20 or so that we tore down to find out what had happened...I found that all of them had +.030 to +.045 shim packs.....I thought that I was not calculating it correctly or that the failed units were too bad off to be accurate...
I went to the getrag reman plant way back when to get to the bottom of what the problem was..... I pulled 3 off of the line and tore them down to check the clearance....They all had +.030 to +.045 shim packs in them as well..... Oh sh** ! I called for the production manager ....We discussed my findings...He said that they set them up this way intentionally because they felt .006 was too lose and caused excess gear rattle during testing...OMG !!!
I promptly told him that he was to stick to the spec that WE told them to use and that I was going to write my report to my superiors that Getrag was the cause of the failures and should be back charged for the failures of the remans that Chrysler had had to eat in the previous 3 years!
For those of you that have had one of the Getrags apart . You may have noticed the the rear main shaft bearing race was excessively thick....
The reason for this was that when we were testing the very first Getrags we found that under excessive load that the standard race would split and crack the case...So we reduced the size of the cone and had Timkin make a special thick walled race....It worked and hence the reason for the strange heavy race...
The best thing to do is rebuild the Getrag PROPERLY and put it back in....
There is nothing wrong with the Getrag if you know how to build them !
I have written quite a bit on this subject in the past...Look up the posts...
I know that many think that the NV4500 is a better trans....But we did have the 4500 several years BEFORE the Getrags were used...The 4500 was only used for gas trucks originally....We used the Getrag because it was found to be a better trans during testing.....The 4500 was later used behind the diesels...It had a few small changes made to it before it was used in the diesels but that was it....
The 4500 replaced the Getrag for only one reason...cost !
Rebuilding the Getrag is not hard you just have to pay attention to details...
The Getrag's problems were few but vital... The things that made them fail were as follows...
1) OIL LEAKS
A) drain plug dripped , run out or run low on oil
B) No gaskets on early models , more leaks
C) pilot bushing failures,,, bronze was too soft
D) over loading , trailer too heavy
E) too much hp , turning up the fuel/air
F) overheating ruining the oil
G) wrong type of oil , no 90 weight in the Getrag ! !
H) not knowing how to shift , rattling the gears,, too high a gear at too low a speed
2) Poor assembly
A) setting shim packs too tight , Getrag even did this themselves at times
B) uneven shim packs between main shaft and countershaft causing tail shaft housing not to hit squarely
C) bell housing misalignment
In conclusion, I personally have never had a Getrag fail in any of my personal trucks nor have I ever had to rebuild one twice that I built,, I have seen them go hundreds of thousands of miles in fleet trucks without failures.....
If you still decide to replace it with some thing else I would be glad to buy whats left of your Getrag.. I could use the spare parts ...
Good luck and be sure to replace the pilot bushing. Preferably with a ball bearing... The flywheel will need to be bored out for this...I do my own but the guys at South Bend clutch do them all the time for people.....
As for the pilot bushing....Engineering knew it was not going to work before the first one left the plant...But if you did not haul trailers it would work long enough to get out of warrantee....Engineering wanted to use a ball bearing but . We were shot down due to cost ...
In 94 it was decided to go to a Torrington needle bearing...Great in theory but it just made matters worse....They ate the imputs alive....
As for the worn out ends on the imput shafts...What I do is put them in my cylinder grinder and make them round and back on center..Then I make a steel sleeve on the lathe and press it onto the shaft end.... Then I put them in my cylinder grinder again and finish them to the correct diameter for the ball bearing I am going to use ...The tolerance is .0001 ot centerline . And no your Craftsman engine lathe you got from dad is NOT going to do the job accurately enough !
DJ Turbo.
Oct 13, 2011 09:11 PM
mbaker
May 23, 2011 10:50 PM
yebatza
May 7, 2006 01:25 PM
cummins1279
Jun 15, 2005 11:24 AM
TexasBlake
Feb 23, 2004 01:26 PM
