93 fan shroud
Old Feb 26, 2014 | 09:58 PM
leverman's Avatar
93 fan shroud
Recently bought a 93, and it is missing the fan shroud.
is there any other years that fit? seems to be a hard to find item. thanks
Old Feb 26, 2014 | 11:25 PM
simplysmn's Avatar
91.5 to 93 fit but good Luck finding 1 they are no longer made and hard to get .
Old Feb 27, 2014 | 06:04 AM
Where are you located, as I have several in my shop.
Old Feb 27, 2014 | 11:34 AM
james1's Avatar
Question
Again, I'm in danger of showing my ignorance, but is the fan shroud (plastic) this a part that could be replicated with a Three-Dimensional Printer? (I know it is large in two dimensions and I've never seen a 3D Printer in operation.)
Perhaps someone with the appropriate experience could chime in?
TIA
Old Feb 27, 2014 | 11:45 AM
bobva's Avatar
3d printer my god
It only takes about a a hour to make one out of sheet metal.
Old Feb 27, 2014 | 02:42 PM
mknittle's Avatar
Originally Posted by bobva
3d printer my god
It took me a couple hours to make one for my jeep out of aluminum sheet and 1"X1/8 angle and a box of pop rivets.
Old Feb 27, 2014 | 04:30 PM
Jim Lane's Avatar
Another part made out rare unobtainium.
Here are some instructions on how to make your own.
Fiberglass Fan shroud.
http://www.crankshaftcoalition.com/w...***_fan_shroud
Aluminum Fan Shroud.
http://www.motortopia.com/worldofrod...n-shroud-1970/
Another Fiberglass Fan Shroud.
http://www.route66hotrodhigh.com/FanShroud.html
Jim
Old Apr 7, 2020 | 12:44 PM
Taylor Bourque's Avatar
Need fan shroud
I am in need of one near Arnaudville Louisiana.
Still have?
Old Apr 7, 2020 | 01:45 PM
Still have?
I do still have a few of those in the shop.
PM if you like.
Old Apr 7, 2020 | 04:44 PM
I tried to send you a PM...maybe since you just signed up I can't use that feature...
I have core supports along with basically any other part to fix that front end damage on the Dodge.
Old Apr 7, 2020 | 06:38 PM
Maybe so, I can be reached at taylorjbourque (at) me (dot) com
Old Apr 8, 2020 | 05:21 PM
When I do the cummins conversion on my Ramcharger I plan on using the common 89-91 and 94-02 fan hub but with an intercooled rad support and radiator, so will be making my own fan shroud.
Old Feb 3, 2021 | 05:32 PM
82ndVet's Avatar
93 IC Fan shroud
I'm in need of a 93 IC fan shroud. Do you still have one? Couldn't send you a PM, I'm assuming it's because I'm a newbie. I also need a front PS wheel well moulding.
Old Feb 3, 2021 | 06:17 PM
Welcome to DTR.
Yes I have both of those parts.
Where are you located?
I am in VT
Old Feb 3, 2021 | 10:24 PM
82ndVet's Avatar
Welcome to DTR.
I am in VT
I'm in Idaho, give me a call or text when you have time 2082169056
