93 electrical system will not charge
Unable to locate problem in charging system after full engine out rebuild. New battery, new alternator, yet while running the battery continues to drain. Volts measure 11.7 at the battery and at the alternator output. I think the engine does not have an air temp sensor on the intake manifold. Just behing the air intake there is a place for a sensor but it is unplugged, deleted in the wiring harness.
Re:93 electrical system will not charge
First off, welcome aboard..
Search Crank Sensor in this area and you will fix your problem. With the suspect wiring harness, this component may have been overlooked during the overhaul process.
There was a thread with a similar problem not long ago, try page 2 or 3 of this area.
J-eh
J-eh
Here is the thread, it was on page 4 by spitzair
http://www.dodge-diesel.org/yabbse/i...threadid=21659
There is also another few post further back, try the search function..
J-eh
J-eh
You guys ROCK! The unanimous solution to my problem was right on. I reduced the gap of the crank sensor and Bingo! I have Power. Thanks to DRT and contibutors.
i am so glad to find this sight! I have been having the same problem in my truck and am in the process of rebuilding the truck. This is great to have feed back!
maddddog
Aug 16, 2019 07:20 AM
August13th
Nov 9, 2010 11:29 AM
12ValverDave
Sep 5, 2007 07:04 AM
Tiara3100
Mar 7, 2007 12:26 PM
