93 D350 A518 Downshifting
Old Mar 3, 2012 | 04:18 PM
JTCHess's Avatar
Need an assist on this one. My 93 D350 is bone stock and just turned 94K. Owned the truck since 1998 and pretty much know it's maintenance history. Installed a new TPS about 5 years back to address a shifting issue which it resolved. Now my truck has developed a habit of frequently downshifting out of overdrive. Just went through all the connections with WD40 to ensure a good connection. Am I missing something? Thought perhaps it was time for a new tranny since the truck pretty much has been a hauler its entire life; truck camper, 5th wheel RV trailer, and now a horse trailer but think it's more of a electrical issue. Thoughts?
thx,
John
Old Mar 3, 2012 | 04:28 PM
Onemoparnut's Avatar
Look in the sticky there is a test there for the tps sensor. Sounds like a bad tps but it could also be other problems. Start there and test the tps and see what you find.
Old Mar 4, 2012 | 03:13 PM
JTCHess's Avatar
Problem solved, Bill thanks for the input just the same. Just retuned from a horse show and no down shifting issues. Solution: sprayed the TPS wire connector with WD40. Suspected some moisture in the connection.
While I was at it I did my annual rust prevention spraying of WD40 into the cab roof/ceiling panels using the sun visor holes.
WD40, I love that stuff...
John
Old Mar 4, 2012 | 03:25 PM
Glad you got it fixed
Old Mar 4, 2012 | 05:15 PM
j_martin's Avatar
I thought these weatherpack connectors were supposed to be weatherproof. I guess they aren't.
I have the same intermittent shifting issue. Also have had the TPS wack out in foggy weather.
Grabbing the WD40 and heading out the door.
Old Mar 4, 2012 | 05:25 PM
NE frmhnd's Avatar
I'm not sure I would use WD40 as a rust preventer. I put some on a shotgun once and it rusted just about overnight.
Old Mar 4, 2012 | 08:16 PM
j_martin's Avatar
Actually, I reconsidered. I will clean the connectors with electronic cleaner, which is mostly isopropynol, and flash dries without residue, then lube it with silicone dielectric grease.
I don't know what happened with your shotgun, except that the acids from human hands are pretty nasty on fine steels. I hose down the wood splitter with WD40 and cycle it a couple of strokes when I park it. I leave it exposed in the weather with little rust.
O'Neill
Dec 31, 2004 08:35 PM
Jc9995
Jul 11, 2004 05:45 AM
mr T
Apr 19, 2004 09:38 PM
parscomm
Jan 3, 2003 11:28 AM
Blowndodge
Nov 7, 2002 03:56 PM
