92 w250 trans and tc questions
I'm preparing to change fluid on both tranny and TC what fluid type should I use on them?
Also, what auto transmission comes on this model year truck? I'm not sure yet since I didn't drive it much but I don't think is has OD.
I searched the sticky but didn't find a lot, most seem to replace them with another transmission, is this what I should plan on doing? I was hoping I could add a GV behind it at some point but I'm open to other possible options.
Thanks.
Thanks.
It will be an A-518 Trans, It has overdrive. It is sometimes referred to as a 46RH but most of the time it's called a 518 - It has a non lockup torque converter.
You wanna use ATF+ fluid....ATF+4 is what's around these days, and the best
some people swap in a 47RH A-618 trans from a 94-95 truck, just to gain the lockup torque converter
I see, I just change the fluid on both then, for now.
Where exactly do I put the probe for a aftermarket trans temp gauge, some one told Me on the factory location but I have no idea where it is. I will be a glowshift 3 combo.
Thanks.
Thanks.
TexasHardcore
Aug 29, 2004 12:20 AM
